It is currently Sat May 09, 2026 3:46 am
PostPosted: Sat Jan 28, 2012 6:38 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
For the 3 rd time my gear motor has quit working which turns the conveyor belt.. Having a difficult time locating the problem .It has a speed control. an reversing switch, Several times i manually turned the conveyor belt and had it running then it stopped again.I had redone the wiring connections 2 weeks ago from the reversing switch to the gear motor.Finally the conveyor belt would not fire up after turning it manually. I tried to hook up the speed control directly to the gear motor, nothng,so the problem is either in the speed control or the gear motor .The machine is 2.5 yrs old. lightly usedThe reversing switch was working when I got the machine running by turning the conveyor belt manually.My electrician friend says its either a defective speed control or a capacitor in the gear motor gone bad?suggestions?
PostPosted: Sat Jan 28, 2012 8:11 pm
First name: Rusty
Have you contacted a technician at woodmastertools.com?
PostPosted: Sat Jan 28, 2012 8:43 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
thanks rusty I did last time , their closed on the weekend.Will call monday morning
PostPosted: Sat Jan 28, 2012 11:49 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Quote:
My electrician friend says its either a defective speed control or a capacitor in the gear motor gone bad? suggestions?
Isn't it a DC motor? They don't have capacitors.
I would check the output voltage of the speed control. If it is a DC motor (which is most common on these devices), you should have DC voltage, no AC. I suspect that the rectifier has gone bad.
PostPosted: Sun Jan 29, 2012 9:40 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
John your right, abt the capacitor I tried hooking up a 12 v dc battery charger last night directly to the gear motor , and nothing happened.There are 2 leads coming out of the speed controller wired into the reversing switch. Does that mean that the speed control converts the ac voltage to 12 volts DC?? If so , would that be 12 volts converted by the rectifier into the reversing switch. ??Thanks ernie
PostPosted: Mon Jan 30, 2012 5:03 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
After spending quite a bit of time trying to fix my sander, I called woodmaster this morning, even though my sander is out of warranty, they gave me a speed controller to test my gear motor, which was intermittent, I called back, and returned with a new gear motor.I am very appreciative, of their kindness
PostPosted: Mon Jan 30, 2012 10:55 pm
Last Name: Arnold
City: Newport
I am glad you found the problem. The voltage output of the speed controller is DC, but it is variable.
