It is currently Fri Jun 12, 2026 11:41 pm
PostPosted: Mon Mar 12, 2012 1:26 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
I'm starting back on an OM I put aside a while back. I had it in an adjustable mold but removed it. The back is on and I am prepping the sides to attach the top. Since it was an adjustable mold the mold no longer has the original form. My concern is keeping the sides parallel without the mold and spreaders. It is difficult to check the square of the side due to the radius on the back. Should I try to reset the mold and and glue the top or can the top be glued on outside of the mold?
Richard
PostPosted: Mon Mar 12, 2012 5:07 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
How square, or out of square are the sides? I know you say it's difficult to check due to the back radius, but do they look square? I'd say if they look good, don't worry about it. My OM mold is hanging on my wall empty right now if you want to use it. Assuming it's the same "OM" as yours.
PostPosted: Mon Mar 12, 2012 8:56 pm
I use an adjustable Fox type mold and level the body with wedges and a support under the head block. You can use your spreaders and adjust to get everything square. I've done a lot of guitars this way. It works for me.
PostPosted: Mon Mar 12, 2012 8:59 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Thanks Terence and Woody, I went ahead a installed it back into the mold. Will get saturated in the top soon
Richard
PostPosted: Fri Mar 16, 2012 2:29 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I wonder if you could make a guitar more comfortable to use sitting down if it had one or more out of square sides? An angle might make it sit on the thigh a bit better (????)...I want to try this some day.
PostPosted: Fri Mar 16, 2012 2:59 am
Sounds like a nightmare scenario to build and bind, and I'm not sure how it would look...what does work is a wedge, however. Tilts the guitar back towards the player a little.
