It is currently Thu Apr 30, 2026 12:48 pm
PostPosted: Sat May 05, 2012 5:37 pm
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
Hi- I am able to buy plastic scraps at my local surplus store. But I have to take what I get I want to make some jigs and would like to laminate some pieces. What is the best glue for the white UHMW? Thanks
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Sat May 05, 2012 9:14 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Contact cement. Apply to both surfaces, allow to dry then press together.
I put UHMW strips (or maybe Delrin?) on the base of my router table & they haven't come off after almost 20 years. Actually, I think it's been 20 years as of this year but it make me nauseous to think about it.
Kevin Looker
I'm not a luthier.
PostPosted: Sun May 06, 2012 12:09 am
Todd Stock wrote:
...... UHME-PE threads and hold fasteners in adequate thicknesses........ I prefer Delrin, with it's higher strength and greater ability to hold threaded fasteners......
Here's a good tip - When threading plastics like UHMWPE, it is best to use UNF threads instead of UNC. It holds the thread much better. In other words -use 4-48 instead of 4-40, 10-32 instead of 10-24 etc.
PostPosted: Sun May 06, 2012 1:10 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I make my jigs out of scrap plywood because they're always around, and because I have no clue where to find UMHW plastic in Taiwan. I can find acrylics though.
Typhoon Guitars
PostPosted: Sun May 06, 2012 10:11 am
Last Name: Sterling
City: Ulster Park
State: New York
Thanks for all the input. Apparently there is a company here that makes plastic cutting boards and my surplus guy gets it when he can. I have some scrap corian and I was wondering if it is any different than the kind used for nuts and saddles. This came from a cut off from a counter top. I met a woman at a woodworking show that makes fancy cutting boards out of scrap corian and she said she uses ca. What is corian anyway?
PostPosted: Sun May 06, 2012 10:49 am
First name: Stuart
Last Name: Gort
You can also get acrylic transfer adhesive which will hold it well.
The bond increases with age with acrylic adhesive.
StuMusic
PostPosted: Sun May 06, 2012 7:36 pm
Last Name: Garrish
Gluing any sort of polyethylene (PE, HDPE, UHMW (which is really UHMWPE)) tends to be a bad idea.
Acrylic glues well with acetone, or with a mix of acrylic and acetone if you need to fill gaps.
Corian is essentially acrylic, just with dyes and some fillers added, the only other ingredients besides dyes and pigments are to make it fire/smoke resistant. It's a trade name, so it's definitely all the same stuff.
Bob Garrish
PostPosted: Sun May 06, 2012 8:34 pm
Heat fusion is the only way to glue olefin plastics like polyethylene and develop 100% of the strength of the parent material. Any adhesive used would rely on a toothed mechanical bond, which in lower stress situations, would likely be enough.
PostPosted: Mon May 07, 2012 5:28 pm
First name: Nelson
Last Name: Palen
Need to machine miniature dovetails in the UHMW surface(s) to be bonded. :D
PostPosted: Tue May 08, 2012 1:30 am
First name: Hugh
Last Name: Evans
Polyethylene is used as a release paper for adhesives. Techniques such as corona treatment only make a bad situation better, and bond strength will rarely exceed 200 psi. Pressure sensitive adhesives (PSA) are among the only types capable of such a bond but are, again, weak.
PostPosted: Tue May 08, 2012 2:05 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Hugh--I'm glad to see that you're still here. I appreciate all the hands on experience that preceded your post ( I was going to chime in , and say that double stick tape works fairly well ), but I was left wondering if there was some magic trick that none of us knew about. Sounds like there isn't. 200 psi. would be plenty for most shop jigs, but shear creep is the limitation I can't get around. I'm guessing that Filippo has it right: bolt it down.
