It is currently Sat Aug 16, 2025 1:40 am
PostPosted: Tue May 22, 2012 11:06 pm
I'm planning to tint a guitar with some amber shellac, and then do a wipe on poly for a bit more bulk. I'm worried about the solvents in the poly melting the tint coats and making a smeary mess. Any thoughts/advice?
PostPosted: Wed May 23, 2012 12:29 am
Last Name: Beaver
City: Lake Forest
Never tried it but shellac and poly, unless it is oil based poly and no-wax shellac, may not be a good mix. Better do a test first.
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 23, 2012 7:03 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Wipe on poly will go over shellac with no problem. I do it a lot.
PostPosted: Wed May 23, 2012 9:07 am
First name: Tony
Last Name: C
City: Brooklyn
How about nitro over wipe on poly?
I am having a hell of a time getting the wipe on poly to stay glossy over some macassar ebony. It seems that every other grain line is satin and the rest are gloss. I am at over 30 coats of the poly so far. I assumed I would need to build some finish, but it has built with no shine to show for it. I just want to hit it with some rattle can Deft nitro and leave it be.
May do it anyway to test.
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed May 23, 2012 11:56 am
Tony, does the wipe-on poly feel like its curing? I don't know about macassar ebony, but I do know that wipe-on poly does not cure very well over EI rosewood.
PostPosted: Wed May 23, 2012 1:10 pm
First name: Tony
Last Name: C
City: Brooklyn
Pat,
It takes much longer to stop feeling sticky, so I guess the answer is yes, but slowly. I have put it on EIR and it was fine, but this macassar is giving me problems. I think I may just sand it off ans spray some nitro on it. I like the feel of the poly on the neck and the mac. ebony is a back strap. The front of the head stock is getting nitro anyway, so I may as well just spin the neck around and shoot the back strap as well.
Thanks for the info.
Tony
PMoMC
PostPosted: Wed May 23, 2012 1:50 pm
It'll work fine, as long as you make sure your shellac is dewaxed, otherwise the poly won't stick to the shellac.
Don't do this, the nitro won't stick to the poly. What you are experimenting is what Pat is suggesting; the oils in the ebony prevent the poly from curing. Scrape off the poly and seal with a couple of coats of shellac, that'll solve your problem.
Alain Moisan
(Now building just for fun!)
PostPosted: Wed May 23, 2012 1:56 pm
First name: Tony
Last Name: C
City: Brooklyn
Thanks Alain! I will do just that. Fortunately the wipe on poly takes a long time to build so it wont take lone to sand or scrape it off.
PMoMC
PostPosted: Thu May 24, 2012 2:09 pm
First name: Tony
Last Name: C
City: Brooklyn
I shellacked last night and then put on the poly and it has cured! Thanks for the help!
PMoMC
PostPosted: Thu May 24, 2012 3:45 pm
Glad to know it worked!
Alain Moisan
PostPosted: Wed May 30, 2012 7:54 am
First name: Tony
Last Name: C
City: Brooklyn
You and me both!
PMoMC
Users browsing this forum: TimAllen and 10 guests
