It is currently Wed Aug 13, 2025 5:21 pm
PostPosted: Wed Jul 18, 2012 12:39 pm
First name: Lee
Last Name: Eichelberger
City: Red Lodge
State: Montana
Zip/Postal Code: 59068
Hello again,
I was wondering what some of you use for jigs to glue up your bookmatched backs and soundboards.
I have seen a couple different set-ups, but would like to see some new ideas.
Pictures would be great!
Thanks-
--Leanu--
PostPosted: Wed Jul 18, 2012 5:09 pm
Masking tape.....
PostPosted: Wed Jul 18, 2012 5:28 pm
Tape for me too, with HHG
PostPosted: Wed Jul 18, 2012 5:29 pm
Binding tape.
PostPosted: Wed Jul 18, 2012 6:03 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
Here's what I use and it's pretty much foolproof...at least it has been for this fool! All you do is butt one plate to the far left side and then screw down the board that is just left of center on top of the plate. Glue up the second plate and lay it down for joining (wax paper underneath), place a weight on the plate and turn the tightening wedges on the right for a perfect clamp up. Fool proof!
PostPosted: Wed Jul 18, 2012 6:18 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
Scotch 233 tape with Fish Glue or TB.
if it's good enough for the greats, it's good enough for me.
PostPosted: Wed Jul 18, 2012 6:21 pm
+1
PostPosted: Wed Jul 18, 2012 7:08 pm
First name: Tim
Last Name: Allen
City: San Francisco
For gluing plates together that don't want to lie flat, I've used the eccentric cams, above, as Mark shows, only instead of weights I hold the plates flat with go-bars in the go-bar deck.
Tim Allen
"Never hurry, never rest."
PostPosted: Wed Jul 18, 2012 7:43 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Binding tape, made a jig once but tape works as good or better so I ended up using the parts for some other task
Fred Tellier
PostPosted: Wed Jul 18, 2012 7:56 pm
Last Name: coloccia
Country: States
Tape or eccentric clamps, depending on my mood. On real advantage to tape is you don't ever have to square or otherwise shim the outside edge of the plates.
PostPosted: Wed Jul 18, 2012 8:35 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
plus 10 on the tape!!!!
MK5acoustics.com
PostPosted: Wed Jul 18, 2012 9:13 pm
First name: Fred
Last Name: Tellier
City: Windsor
The best jig in my shop is the tape dispenser, heavy enough to be used as a weight on things and always close by when needed.
Fred Tellier
PostPosted: Wed Jul 18, 2012 9:26 pm
Last Name: Kincheloe
Blue tape :)
I used to put down wax paper, clamp one half of the plate down to the bench, and blocks to the other side of the bench, to where I could stick wedges in to press the two halves together. Tape is a lot quicker and easier, plus it keeps the show face clean of glue so you don't have to mess around with scraping it off later. But I'd use the old method if I was attempting to glue a plate that wouldn't lie flat, since it would peel the tape off before I could get the glue in and weight it down.
I just made my two best plate joins yet yesterday, using my recently completed wood plane (pecan and black cherry with Krenov-style Hock blade). So nice to finally have something reasonably flat and long, not to mention lighter weight and smooth edged so it's easier on the hands.
PostPosted: Thu Jul 19, 2012 12:22 am
rope and wedges
PostPosted: Thu Jul 19, 2012 1:57 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I use transparent packing tape. I have seen elaborate jigs and people even using bar clamps. This is simply the easiest and one of the most efficient way to do it....Mike
Another day, another dollar.
PostPosted: Thu Jul 19, 2012 7:27 am
Another one for the 3M 233 green masking tape with HHG.
PostPosted: Thu Jul 19, 2012 7:42 am
Last Name: A
Sometimes I make shift something on my bench - other times I use tape. Really anything works that keep the joint tightly pressed together and flat.
PostPosted: Thu Jul 19, 2012 5:12 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
That's a nice looking plane, Dennis. [clap]
PostPosted: Fri Jul 20, 2012 3:02 am
Country: England
So do you guys thickness your plates pre or post jointing?
Thanks, Ed.
PostPosted: Fri Jul 20, 2012 5:32 am
I use Cumpiano style, flat board, wedges, wax paper, and weight for the center.
Chuck
PostPosted: Fri Jul 20, 2012 6:33 am
Thanks, Ed.
Its much easier to thickness after they are glued up, as it makes aligning the plates less critical.
As for jigs: I've used the Cumpiano method, ropes and wedges, tape, but now I'm back to... (drumroll) clamps! They are within reach from my glue-up table, so no set up time to speak of, and they are easy to use even when I use a purfling strip between the halves, as in the picture. What's not to like about it?
PostPosted: Fri Jul 20, 2012 6:35 am
Thanks, Ed.
I join first, scrape the show face smooth and shellac it to keep it clean, cut out the shape, do the majority of thicknessing with my trusty block plane, tapping and flexing to judge how far to go (I just use my fingers, no fancy deflection testing setup), then cut out the soundhole so I can really get a feel for the flexibility of the bridge area, and scrape to final thickness. The final scraping step usually involves working on the show face side as well, since it's tough to avoid getting any wood chips underneath and denting it during the plane step.
PostPosted: Fri Jul 20, 2012 6:44 am
Thanks, Ed.
After joining although if the material is rough cut I'll usually run it through the sander a few times to even it out a bit (as long as I have enough thickness available).
PostPosted: Fri Jul 20, 2012 8:42 am
First name: Kevin
Last Name: Smith
City: Decatur
State: GA
Zip/Postal Code: 30030
I tried everything else before this. It'll hold odd-size stuff like tele bodies also.
PostPosted: Fri Jul 20, 2012 10:36 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
Am I right in thinking that Overholtzer didn't use any clamping method for the tops, just rubbed the glue line together and left it alone?
We are all in the gutter but some of us are looking at guitars.
Users browsing this forum: Melt in the Sun, Michaeldc, Mike Thomas and 38 guests
