It is currently Sun Aug 03, 2025 1:06 pm
 Post subject: Top Crack Repair
PostPosted: Sun Jul 22, 2012 12:09 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I'm sure this has been covered many times but I can't find a comprehensive thread that goes over the entire procedure. If someone can point me toward one, please do.
So this is my No. 1, a Martin Dred kit. The top was glued up when the RH was a little high & it suffered a very dry winter which resulted in the bridge coming loose & a crack opening up.
The crack extends from the purfling up to the tape.
Here's a tighter view.
My simple question is what would be the best way to repair this? I suspect the answer is not so simple.
The crack is pretty tight. I can push down on one side to open it up & inject some HHG. Will the water in the HHG cause the wood to expand a little and tighten the joint?
I suspect that cleats on the inside would be a good idea but I can't get my hand down there on the inside.
Kevin Looker
I'm not a luthier.
 Post subject: Re: Top Crack Repair
PostPosted: Sun Jul 22, 2012 7:34 pm
You need to also clamp on the top to keep the joints flat. HHG is the ticket for this
PostPosted: Sun Jul 22, 2012 11:38 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Frank Ford has some good info on crack repairs over at Frets.com
Another day, another dollar.
PostPosted: Mon Jul 23, 2012 6:14 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I really hate those kinds of crack, because few clamps exist out there that can reach it... and they're usually expensive.
I sometime clamp from the outside to keep things flat. Once wood shrinks, it most likely will never grow back so if it opened too much you will need to fill it with additional wood to close the gap. Make the patch wedge shaped and it will virtually disappear.
Typhoon Guitars
Users browsing this forum: Bing [Bot], CarlD and 16 guests
