It is currently Sun Aug 03, 2025 3:42 pm
 Post subject: Zpoxy dry times
PostPosted: Thu Jul 26, 2012 12:26 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
It says 30 minutes.
How long until I can sand it? 30 minutes or do you wait longer?
I'm not ready to sand yet, but when I am I'd like to not screw it up. I still have to fill the sides and rosette as well. Plus it looks like it could use another coat?
How many coats is typical?
 Post subject: Re: Zpoxy dry times
PostPosted: Thu Jul 26, 2012 2:55 am
First name: Joey
Last Name: Holliday
City: Palmetto
Yeah it's the 30 minute Zpoxy finishing resin. I wasn't sure which to get but I was worried that the 5 minute would harden up too quickly and I'd be stuck with a lot of sanding. The 30 minute went on pretty easy after thinning with alcohol and was pretty workable for a decent amount of time. It hardened up enough to work the sides and rosette after about an hour and half but was still tacky. I'll probably finish the other side in the morning and try to start sanding Friday night or Saturday morning.
What is it about the 30 minute that you don't like outside of the longer curing time?
PostPosted: Thu Jul 26, 2012 8:03 am
First name: Tony
Last Name: C
City: Brooklyn
According to the manufacturer, Z-Poxy is designed to be used with nitro and there should be no adhesion issues with nitro right onto the Z-Poxy. I have found that if I do a coat of Z-Poxy in the morning, I can sand and recoat in the late afternoon, so several hours is probably the minimum, however, you will know very quickly if you are sanding too early.
Great stuff.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Jul 26, 2012 3:08 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I've never put a finish on a guitar before outside of Tung oil. The wood just popped, that was easily one of my favorite processes in this entire process. It already looks amazing. Now to not screw it up.
Speaking of Tung oil....I want a matte tung oil finish on the neck. Should I pore fill the neck as well or not? Any issue with Zpoxy and Tung oil adhesion? Or is it ok by itself? Doesn't seem like it would work since Tung oil is a penetrator and the zpoxy is essentially blocking the way to the wood.
PostPosted: Thu Jul 26, 2012 5:02 pm
First name: Mark
Last Name: Morris
City: Sedona
State: AZ
Zip/Postal Code: 86339
+1 on one coat per day!
PostPosted: Thu Jul 26, 2012 7:33 pm
First name: Tony
Last Name: C
City: Brooklyn
If you sanded the neck back to bare wood it would work, but leave a couple of spots with z-poxy and the finish will look blotchy. I use Danish oil on my necks with wipe on poly over that. It looks great and feels good too. A matte wipe on poly finish could be the ticket for you. Anyway, I pore fill my bodies with z-poxy but the necks with TimberMate for the reasons above. The TimberMate doesnt block the oil from getting into the wood so it still pops the wood figure very nicely, and the poly looks great over that.
Here is a pic of the back of a headstock I finished with the Danish oil/ Wipe on Poly schedule:
It comes out pretty nice.
PMoMC
PostPosted: Thu Jul 26, 2012 9:31 pm
First name: Joey
Last Name: Holliday
City: Palmetto
That looks great and I think that's the ticket for me. Is there a particular color you use for mahogany or are they all clear? Also what brand of wipe on poly and where do you get it? Is this stuff I have to order or does Home Depot/Lowes carry this stuff. I hate to order stuff because it takes forever and shipping to Alaska is pricey.
PostPosted: Fri Jul 27, 2012 12:25 am
First name: Tony
Last Name: C
City: Brooklyn
I purchased the Timbermate from Stew Mac or LMII. I forget which one carries it. however, if you are pore filling mahogany, and the pores are not too big, you could use a wood putty from Lowes or Home Depot. Just watch out for shrinkage, and I'm not talking about the George Costanza kind! laughing6-hehe
There was a thread the the UMGF about grain fillers and someone, a prominent luthier if I recall, mentioned using wood putty. I could be wrong, but for small pored woods, it should be just fine.
Min Wax Wipe on Poly is available at Lowe's for sure because that's where I get it. It comes in gloss, semi gloss, and satin if memory serves. Easy as pie to put on. I use good, name brand paper towels as they release little to no lint. Wipe on the thinnest of coats and let dry. Since it takes a while to flash, the surface stays tacky for a while and can attract dust and flying insects. You can knock those off with 600 or 1000 grit paper before your next coat, but I usually do 3-4 coats, knock off the nibs, then repeat until I have the desired build. It builds slowly so don't be in a rush and try to put on a thick coat. You will get a better, smoother finish with less sanding if you do many thin coats versus trying to apply it thicker. I can usually do 2-3 coats in an evening if I put it on thin enough and it's warm enough out.
I use nitro on the body, so having enough time to apply plenty of coats of the poly is no issue. I start when I am starting the box, then keep applying while it dries so I end up with two weeks worth of time to apply many coats of the poly.
One word of caution: Wipe on Poly will not cure over oily woods. The neck in the pic I posted had a macassar ebony back strap and the poly would not cure over it. After about a dozen coats, I had to sand it off, apply shellac as a barrier, and then start over. It turned out fine as you can see, but half of the grain lines were matte finish, half were glossy, and all of them were tacky while the rest of the neck was fine. I have used it on ziricote, bloodwood, walnut, maple and mahogany without incident. That darn macassar ebony was the only problem wood so far. I suspect cocobolo would be problematic as well.
Oh, and I have been using nitro on the front of the headplate lately, but I did do one guitar with poly on there and it turned out fine. Here is a pic of that:
Not a great pic because you can't see the shine very well, but it was shiny. Really. I used nitro so I could bury my logo decal under it and sand it flat.
Good luck and post pics.
PMoMC
PostPosted: Fri Jul 27, 2012 6:02 am
Just so we're clear:
There are three products made by Zap that have been mentioned:
- Z-Poxy 5 minute epoxy (PT-36, PT-37, PT-38)
- Z-Poxy 30 minute epoxy (PT-39)
- Z-Poxy Finishing Resin (PT-40)
I don't use the 5 minute (or any 5 minute) epoxy because I have other glues for short working time. The 30 minute is a perfectly adequate, easily sanded and worked structural epoxy designed for gluing things together. I've used it on fingerboard to neck joints and laminations before without trouble, although I currently use WEST systems stuff instead.
Finishing resin (a different product entirely) is what I and others use as a pore filler. It's thinner, easier to apply, easier to sand and possible a little clearer than the 30 minute variety. I allow at least 24 hours to cure before re-coating.
PostPosted: Fri Jul 27, 2012 2:44 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Thanks for clearing that up. I used the wrong stuff! I thinned the PT-39 with alcohol and used it as a pore filler. I suppose I have a lot of sanding to do, outside of being a little dark it looks alright.
PostPosted: Mon Jul 30, 2012 9:30 am
Last Name: O'Melia
City: Huntsville
State: Alabama
Does this 30 minute version have the same color as the finishing resin? (PT-40, system 3)
PostPosted: Mon Jul 30, 2012 10:20 am
Last Name: coloccia
Country: States
It'll be fine, Joey. It just won't sand quite as easily. The finishing resin sands easily without clogging. While we're on the subject, West epoxy makes a fine epoxy for this kind of work too, and that's actually what I tend to prefer....maybe because it's just what I'm used to. They have several different hardeners...a normal, a slow and a clear. I just lent a bassist I know my can of resin, he went out and purchased the clear hardener/pump and finished off his heavily graphite reinforced bass that he's been building. Looks awesome.
PostPosted: Wed Aug 01, 2012 1:12 am
First name: Joey
Last Name: Holliday
City: Palmetto
I honestly don't know. I'm just kinda winging it and obviously I've made several mistakes, but I've learned a lot from each one. I'm wondering if this thing is ever going to get finished.
I can say that the color seems pretty dark, but I actually like that. I haven't sanded anything off yet and I have no idea how it will buff, if at all but I've got a half a mind to just use the finishing resin for the finish. I really don't want to sand it off. This guitar has a million things wrong with it already and I can always try something else on build #2 with a little experience under the belt.
PostPosted: Wed Aug 01, 2012 1:15 am
First name: Joey
Last Name: Holliday
City: Palmetto
Hey Tony, how many coats total do you use to get the finish to look like that?
PostPosted: Wed Aug 01, 2012 7:29 am
First name: Tony
Last Name: C
City: Brooklyn
A bunch. I usually do 3-5 coats a day for a week or until it looks good. The poly builds slowly.
PMoMC
Users browsing this forum: meddlingfool and 35 guests
