It is currently Wed Aug 13, 2025 3:32 am
PostPosted: Wed Jul 25, 2012 7:17 am
Mine died, and I didn't like it much anyway. Polling folks as to which one you like and why. This is only going to be used for power stringing up guitars for set-ups.
PostPosted: Wed Jul 25, 2012 7:33 am
I've had cheapies, and high dollar stuff (Milwaukee).
Plain old plastic winders are the best.
PostPosted: Wed Jul 25, 2012 8:00 am
I've used various cheapies, but they usually work really slow, take a long time to recharge, or they break etc. so it gets old. I went shopping locally for a good one for this exact purpose a couple of years ago, and ended up with a little Bosch, I believe its this one
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=PS31-2A
I would have preferred a straight handle (not pistol grip) type, but I haven't seen one that is nearly as well built as the Bosch, at least not over here. It is compact, light, fast, recharges quickly, and I've gotten used to the handle geometry. The Stewmac stringwinder thingy lives on it permanently, and its probably one of my most frequently used tools.
PostPosted: Wed Jul 25, 2012 9:20 am
I have a little pneumatic die-grinder thingy. You can control the speed reasonably, and it makes that cool noise.
PostPosted: Wed Jul 25, 2012 9:54 am
First name: Gary
Last Name: Lee
Ryobi, as recommended to me by an appliance repairman.
Here
Strong, reliable, and holds a good charge.
PostPosted: Wed Jul 25, 2012 9:55 am
First name: Trevor
Last Name: Gore
City: Sydney
There's always the Penguin if you can get one in your part of the world.
http://www.goreguitars.com.au
PostPosted: Wed Jul 25, 2012 10:04 am
I like the cheapies you find for a dollar at yard sales. They might be a little slow, but much faster than winding by hand, and although a little "weak" I can still break strings with them if I'm inattentive. Like Filippo, I make my own winder attachments. The ones I have are AA battery powered, which last several weeks at the rate I use them.
If I were doing set-ups on a daily basis and winding hundreds of strings a week, I would use a small cordless screwdriver or drill with a clutch so I could set the clutch to "slip" before it breaks the string.
PostPosted: Wed Jul 25, 2012 12:42 pm
I've taken to searching the thrift stores for various power tools. I just recently got a great router. Aluminum body and adjuster, small, made from the sixties. Awesome tool!
I've been looking for power screw drivers recently and have run across a couple without chargers. I've seen other tools with chargers and good to go.
I don't really care about the shape of the batteries as I can make a new pack if I have to...I could even make a charger too if I had too. Maybe I will. Thrift stores are great for these kinds of things. 5$-10$ for a new tool is a pretty good deal.
I paid $7.00 American money for my router. I did have to replace the cord but I went heavy duty from the original.
I use it constantly...for everything...I'm using it now! Makes a great smoothie! laughing6-hehe
PostPosted: Wed Jul 25, 2012 2:21 pm
I use the stewmac thing in my 18v cordless drill. No sweat.
PostPosted: Wed Jul 25, 2012 3:06 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Bought mine from harbor freight in 92 bliss , one battery died , but the darn thing is still running.
PostPosted: Wed Jul 25, 2012 6:14 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I bought a Black & Decker LI3100. It's small, reasonably fast and the lithium ion holds a charge forever.
For under $30 it's a pretty good deal, I think.
http://www.amazon.com/Black-Decker-LI31 ... ker+driver
I use it with the Turbo Tune.
Kent
PostPosted: Wed Jul 25, 2012 7:44 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I'm with Chris- I like my little plastic winder...
Gene
PostPosted: Wed Jul 25, 2012 8:31 pm
http://www.ebay.com/itm/Ryobi-3-8-in-12 ... 4ab9e97462
this is what I use when I do set up seminars and such It lasts a long time and it isn't fast like a regular drill
PostPosted: Thu Jul 26, 2012 6:29 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
For anyone intersted in cordless drills in general, the best I've found are ones made by Fein. These (German) people invented cordless power tools. Bosh was an apprentice there.
The ones we use in our university have lasted years and are powerful enough to drive a 15cm screw into wood without a pilot hole.
Good weight and balance.
Downside- expensive.
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Jul 26, 2012 3:07 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
There is also Taylor's souped-up B&D $10-$20 driver:
http://www.frets.com/FretsPages/Luthier ... river.html
http://www.unofficialtaylorguitarforum. ... opic=819.0
http://www.youtube.com/watch?v=vyD_t8dFgsY
Instead of making the steel/alum cylinder, it would also work to lock together 1 set of planets, sun, and carrier (the white triangular part in the 2nd link). Then remove the outer teeth of the planets so they clear the ring gear. To lock 1 set (where is that monkeywrench when I need it?), one way is to drill and press-fit pins through the planets and carrier, or planet-to-planet.
David Malicky
PostPosted: Thu Jul 26, 2012 8:32 pm
First name: D
Last Name: S
Back in the old days, I used my thumb and forefinger.
You youngsters are in such a hurry these days.
idunno
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jul 27, 2012 12:59 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Gene
Me too. I tried a cordless winder for a year, when I was just doing set-ups. At the end, I thought I'd given it a fair chance, but I'm still not convinced. Not faster, not easier. Why bother?
