It is currently Mon Jun 30, 2025 12:31 am
PostPosted: Sun Aug 05, 2012 11:18 am
First name: Wendy
Last Name: W
State: Arizona
For in between binding cutter bushing sizes which do you tape, the bushing or the guitar? What kind of tape works best?
Thanks, Wendy
PostPosted: Sun Aug 05, 2012 11:33 am
First name: steve
Last Name: barbour
Country: U.S.
I have used 1/4" masking tape on the bushing. I load up the bushing with tape and remove tape and adjust after test cuts.
Kyle
PostPosted: Sun Aug 05, 2012 11:43 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I just use green masking tape on the body. I had the tape peel off the bearing once & decided to go the other way from then on.
Aluminum "muffler" tape works well if you want to tape the bearing.
Either way, I like to have a protective layer of tape on the sides, where the bearing contacts the wood. Not an issue with harder woods, but softer material like koa and walnut can easily develop a ridge where the bearing compresses the wood.
PostPosted: Sun Aug 05, 2012 11:45 am
Never had much luck with adding tape to the bearing itself; if the tape comes off, you instantly get a deeper cut. Not good...
I put tape, regular 3M masking tape, on the body itself. Build-up the layers to achieve the required cut depth.
PostPosted: Sun Aug 05, 2012 12:58 pm
First name: steve
Last Name: barbour
Country: U.S.
Roll the tape on in the opposite direction the bearing would be turning.
Kyle
PostPosted: Sun Aug 05, 2012 3:05 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks, I thinnk I'll go ahead and tape the guitar. I hate to have tape come off the bearing in the middle of a cut.
Wendy
