It is currently Sat Jun 28, 2025 6:24 am
 Post subject: Drum Sander Grits
PostPosted: Mon Aug 13, 2012 7:58 pm
Last Name: Waldsmith
City: Bark River
State: Mi
Zip/Postal Code: 49807
Got a new used delta 18x36 this weekend! Finally got it greased up and leveled and really pumped! I got a free roll of 60 grit
paper with it and dont really want to waste it, is it ok to use 60 grit for general sanding of the top, back and sides? What do you use?
 Post subject: Re: Drum Sander Grits
PostPosted: Mon Aug 13, 2012 8:02 pm
I start with 60 then go to 80 and 120 as I approach the thickness I am after.
PostPosted: Mon Aug 13, 2012 8:09 pm
Last Name: Conery
I just use 80 to get close and then hand sand from there.
http://coneryguitars.com
Kill your television!
PostPosted: Mon Aug 13, 2012 9:10 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I use 60 to get close on back and sides, 80 for rough sanding tops, 120 to finish to final thickness. FYI delta belts for these sanders are on sale quite cheap on Amazon.com.
Fred
Fred Tellier
PostPosted: Mon Aug 13, 2012 10:02 pm
First name: Tom
Last Name: Rein
City: Saline
For any oily wood like BRW, African blackwood, coco, etc, I use 36 grit to get within about .5mm and then finish off with a #80 Record cabinet scraper. Not sure if 60 grit would clog quickly, but 80 sure does. Non-oily woods like spruce or mahogany go straight from 80 grit to a card scraper.
Stay with the happy people.
--Reynolds Large
PostPosted: Tue Aug 14, 2012 6:08 am
First name: Miguel
Last Name: Bernardo
Country: portugal
same here, i´m too lazy to change the papers.
PostPosted: Tue Aug 14, 2012 7:22 am
I use 80 for everything cause I don't like changing the papers. Once they're thicknessed then I use an ROS to clean them up. Oily woods just take longer - if you don't take a big bite they don't clog the paper but it takes quite a bit of patience. If I was trying to make money at this I'd probably change the paper.
I also use one of those big eraser-type cleaning blocks every 10 min or so while sanding.
PostPosted: Tue Aug 14, 2012 8:38 am
I use 36 60 then 80 but I also have a belt sander makes changing easier. You will soon find the finer the grit the quicker the sandpaper loads up. What the feed rate and heat.
Finer grits need a higher feed rate and less cut.
PostPosted: Tue Aug 14, 2012 8:17 pm
City: Bark River
State: Mi
Thanks for all the feedback guys! what im hearing is I can probably get away using my 60 grit, just have to do more hand sanding to get rid of marks..... Ey?
PostPosted: Tue Aug 14, 2012 10:36 pm
Err on the side of too thick until you've learned how much wood you lose getting rid of the sanding marks.
Mike Lindstrom
PostPosted: Tue Aug 14, 2012 10:45 pm
City: Bark River
State: Mi
Right on, that was in the back of my head... haha
PostPosted: Wed Aug 15, 2012 7:40 am
In my experience the scratches left by a drum sander for a given grit seem to be deeper than those left by most other types of sanders. 80 grit scratches will take longer to remove completely and take a little more wood, than if made by a beltsander, or so it seems to me.
