It is currently Sat Aug 02, 2025 1:30 pm
PostPosted: Mon Aug 20, 2012 12:22 pm
Last Name: Sollod
I'm contemplating buiding an L-00. I have a template for the Martin 24.9" scale length. Other than not being "authentic", does it really matter if I use the Martin scale length rather than the Gibson? I'd have to spend $40 to buy the 24.75" template...
Any thoughts or comments are welcome...
www.swiftcreekguitars.com
PostPosted: Mon Aug 20, 2012 2:59 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
That's plenty close enough for all practical purposes. As far as being "authentic", Gibson was not terribly consistent over the years, so they probably built at least one with whatever scale you decide to use. Some of the early L-00 probably have scale lengths based on the "rule of 18" instead of the 12th root of 2.
If you're working from plans with a 24.75" scale length, you may want to add the 0.15" difference to the length of the neck.
PostPosted: Mon Aug 20, 2012 3:55 pm
You could calculate the fret spacing for the 24.75" scale and make your own template. I believe Kamamoto's guitar repair book also gives fret spacings for that scale in the back of the book.
PostPosted: Mon Aug 20, 2012 4:23 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
This came in pretty handy when I was designing a 16-5/8" scale uke recently:
http://www.stewmac.com/FretCalculator
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Mon Aug 20, 2012 6:22 pm
First name: Aaron
Last Name: Craig
State: Missouri
Difference between Martin 24.9" and Gibson 24.75" Scale = 0.150" beehive
Use what you've got if you like, just be sure your bridge plate catches all your bridge pin holes. I've built a couple 12th fret 00s with a 24.75" scale.
Aaron Craig
PostPosted: Mon Aug 20, 2012 7:29 pm
Last Name: Sollod
I'm thinking all I need to do is make sure my bridge plate is in the right place. I could shift the bracing 0.15" toward the end wedge... or leave the bracing where it would be on a L-00 template and shift the bridge patch toward the end wedge... Would that make it "forward shifted" bracing?
PostPosted: Mon Aug 20, 2012 7:45 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
The bridge position won't shift 0.15". Some of the added scale length is in the neck. Nut to 14th fret with a 24.75" scale is 13.725". Nut to 14th fret on a 24.9 scale is 13.808". So 0.083" of the 0.15" difference in actually in the neck, not the body. The actual location of the bridge is only .067" different.
PostPosted: Mon Aug 20, 2012 10:04 pm
First name: Ringo
The difference in tension is 2.4 lbs or 1.3% between the two with medium gauge strings. Not much.
PostPosted: Tue Aug 21, 2012 12:50 am
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
Todd Stock wrote:
Easy enough to use WFRET to cut whatever templates you need...think I did all of the common scales for about $2 each. Bass scales run $4 each in materials, although there's usually enough left from a blank to do some uke or mando scales. As to differences, Gibson angles their saddle more than Martin, so that .15 scale length difference is less evident on the bass strings.
I already have a copy of wfret but do you have an active link for those that don't? The MIMF link and the others I had don't work anymore.
Another day, another dollar.
PostPosted: Tue Aug 21, 2012 10:51 am
Last Name: Sollod
Based on what Woody said, it doesn't appear I need to make any adjustments to compensate for the difference in scale length... The bridge patch should be okay where it's located in the template (maybe nudged ~ 0.060"). It appears that the difference is inconsequential.
(Thanks Woody.)
Do others agree?
PostPosted: Tue Aug 21, 2012 5:22 pm
If you want a true Gibson replica you should make sure your pins don't hit the bridge plate LOL.
Yeah Woody is right
PostPosted: Thu Aug 23, 2012 9:09 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Actually it is less than that. Martin's scales include the compensation, while Gibson's do not.
PostPosted: Thu Aug 23, 2012 9:29 pm
Last Name: G
http://api.ning.com/files/cyeJKQVrcVTRo ... /wfret.zip
cheers
PostPosted: Thu Aug 23, 2012 11:33 pm
Last Name: Arnold
City: Newport
I suppose most of the Gibson scales I have measured have been from the period from the late-1930's to the early-1950's. Most of those are 12 3/8" from the nut to the 12th fret.
Quote:
If we are saying that Martin includes the treble side compensation of .040" in the scale length, I would agree - it's the reason why Stewmac calls out a 25.34" scale for Martin (really 25.35 with .040 added at the high E).
I generally add 0.060" to 0.070" for the first string compensation.
Users browsing this forum: Durero and 29 guests
