It is currently Wed Aug 06, 2025 4:47 pm
 Post subject: Ukulele 1st String Buzz
PostPosted: Fri Aug 24, 2012 9:46 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I have come to my last own idea on this. The 1st string (A) is buzzing with most any fret pressed. OK when open. So it's not the nut. I finally put a tall saddle in, no good. No other strings buzz. If I stretch 1st over to 2nd position, buzz. If I stretch 2nd over to first position, no buzz. I've snipped the ends at the bridge. I've checked and double checked the frets.
Could this just be a bad string? I have some new D'Adds I'm going to try tonight. But, before I do that, I'm going to put the 2nd string in the 1st spot, then try the same with the 4th.
Any ideas?
PostPosted: Fri Aug 24, 2012 9:55 am
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Stretch the 1st over the 2nd position?? what's that mean?
PostPosted: Fri Aug 24, 2012 10:04 am
The string is usually the cheapest thing on the instrument.
I often replace them when trying to diagnose the source of weird sounds or bad action.
PostPosted: Fri Aug 24, 2012 3:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, will do. Is there anything special about the shape of the saddle for a uke? I rounded the top.
The stretching of the strings was a vain attempt to mimic what the 2nd string would experience if it were in the 1st string location (weird fret height issue?)
PostPosted: Fri Aug 24, 2012 7:32 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I have a similiar problem on 2 nd fret 3rd string of a current uke build with vy thin frets it could be a hi fret ? I use a machinests 30 60 90 gauge , even 5-10 thou will cause buzzing , or a loose fret lifting in one spot the 2 nd fret on the other strings does not buzz . Using aquila strings. maybe Check the nut slot?
PostPosted: Sat Aug 25, 2012 8:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you all. It turned out to be a bad string. I replaced with slightly heavier gauge D'Adarios and all was fine. My frets were secured with CA. No nut buzz issues.
Users browsing this forum: ballbanjos, dofthesea and 38 guests
