It is currently Sat Aug 02, 2025 1:32 pm
PostPosted: Sun Nov 04, 2012 10:56 am
First name: Heath
Last Name: Blair
City: Visalia
On a recent build, I applied enough coats of finish (KTM-SV) to get a good build, then level sanded. About a month or so has elapsed since then. I now need to apply a few more coats. Do I need to do anything to insure good adhesion since its been sitting so long? Light scuff with scotch brite? Wipe with DA?
sweat the small stuff.
PostPosted: Sun Nov 04, 2012 11:36 am
What happened to make you need extra coats?
I would ask Matt at Grafted Coatings himself, he oughta know. But my thinking is that it's not the kind of finish that will 'melt' into itself, so you'll need to tooth the surface enough for new finish to grab....
PostPosted: Sun Nov 04, 2012 12:22 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Did you buff after you level sanded? If not and the grit was not too fine then all you should need to do is a good wipe down, I prefer denatured alcohol but naptha works fine.
Brian
PostPosted: Sun Nov 04, 2012 3:07 pm
First name: Heath
Last Name: Blair
City: Visalia
I have not buffed yet. My finishing skillz are POOR, that's why I need to apply more finish. Still haven't quite figured it out, I guess. I level sanded with 320 so I think I'll just hit it with DA. Thanks for the advice!
Users browsing this forum: Durero and 26 guests
cron
