It is currently Wed Jul 23, 2025 6:31 am
 Post subject: Lowden Finish
PostPosted: Mon Nov 26, 2012 8:35 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I have a request to build a guitar with a finish having less sheen than high gloss;
the customer has asked for something close to a Lowden type of finish.
I have never done that. Can someone provide me with some guidance here?
I am used to using EM 7000 acrylic lacquer and would prefer to use that but not
buff it to high gloss, if possible.
 Post subject: Re: Lowden Finish
PostPosted: Tue Nov 27, 2012 12:52 am
If you want a satin finish you should use one. I recommend General Finishes Enduro-Var.
If you use a gloss finish there will be places that will gloss up with use.
PostPosted: Tue Nov 27, 2012 3:04 am
I'm fairly confident that lowden uses a water based lacquer (the ones I've seen with dark woods have the blue hue) and then they are levelled and 'satined' by scuffing meticulously with grain using steel wool to knock down the shine. When you hold them to the light you can see the fine scratches...
PostPosted: Tue Nov 27, 2012 4:31 am
First name: Peter
Last Name: Coombe
City: Bega
Zip/Postal Code: 2550
If you are used to EM7000, why not use EM7000 satin?
PostPosted: Tue Nov 27, 2012 8:07 am
Poor way to achieve a satin type finish? I've tried the wirewool method a few times and the fine scratches are always evident.
Perhaps it's better to use a matting agent.
PostPosted: Tue Nov 27, 2012 10:38 am
Perhaps, but a Lowden finish looks pretty snappy...
PostPosted: Tue Nov 27, 2012 10:53 am
. . . even though the scratches are evident? I know that you have to view the instrument/finish at a certain angle to see them but there must be a better way to produce a matte finish. A few coats of Danish Oil is far superior IMO although it obviously won't have the protective qualities of other finishes. At least you don't have to resort to scratches to diffuse the light. Surely matting agents are the way to go.
PostPosted: Tue Nov 27, 2012 11:05 am
Scuffing a gloss finish to achieve a satin one is a bad, bad idea, as it is only temporary. In little time, the player will gloss-up the areas that he/she touches/holds, and then you have a partly glossy, partly satin guitar. Fugly, to say the least..
You want satin, start with satin....
PostPosted: Tue Nov 27, 2012 11:59 am
That happens to poly spray satins as well. Lowdens fetch a pretty fair price, paid for by scrutinizing buyers, sold by discriminating sellers, so it can't be all bad...
PostPosted: Tue Nov 27, 2012 12:57 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Most all satin finishes done on a production basis are accomplished by adding"flatenners" to the coating. It is usually a paste that it's mixed into the coating. Once dried these agents act to refract light rather than reflect it causing a satin sheen while still yielding a smooth surface. You can adjust the sheen by how much you add. I really doubt that anyone building more than a handful of anything for sale and profit is creating a satin finish by scuffing down a gloss. As Todd pointed out that would take as long if not longer to accomplish than a buffed out one, especially if you want it to look even.
Brian
PostPosted: Wed Nov 28, 2012 12:13 am
A wipe on varnish finish can give you a lower sheen. Here's an article with some very good information about making your own wipe on finish. http://www.hardwoodlumberandmore.com/Articles/ArticleViewPage/tabid/75/ArticleId/5/Wipe-on-Varnish.aspx If you want a lower sheen you can steel wool the next to last coat and then apply your last coat and remove almost all of it. It takes some practice but you get a nice sheen without the scratches. I like the Liberon steel wool because it is more uniform and finer than most others and it doesn't have any oil in it. http://www.lmii.com/CartTwo/thirdproducts.asp?CategoryName=Abrasives&NameProdHeader=Steel+Wool You can finish it off with a wax polish if you like.
This is an Arm-R-Seal wipe on oil and urethane finish follwed by a wax polish. It might be the look you are going for. I used a wipe on varnish for the top for more protection.
Ken Franklin
clumsy yet persistent
PostPosted: Wed Nov 28, 2012 10:53 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Thanks everyone.
Users browsing this forum: Michaeldc and 13 guests
