It is currently Wed Jul 23, 2025 1:05 pm
 Post subject: Shellac over nitro?
PostPosted: Thu Nov 29, 2012 3:38 pm
Country: Romania
I am refinishing an old nitro guitar. The owner requested stripping and French polishing.
After scraping the bulk of the nitro off, and thanks to wood distorsion there are still some low spots on the back and sides, still covered by a thin layer of nitro. If i continue scraping i will thin the binding or the higher wood, which I don't want. If I sand them, I will end up with valleys which will look bad under the final gloss, again not good. I've added a few seal coats of orange shellac and the color blending is OK between the clean wood and still lacquered areas. I am thinking that if well scuffed (220 right) there shouldn't be any adhesion problems if i start the French polish now. Also since the nitro is very thin, and harder than the shellac, there shouldn't be any issues caused by future humidity-related movement.
Your thoughts? Thanks!
Build log
 Post subject: Re: Shellac over nitro?
PostPosted: Thu Nov 29, 2012 6:59 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
There should be no adhesion problems. So as long as you are OK with the differences in color caused by the leftover nitro, then go for it. Using orange shellac for the FP will most likely help mask that even more.
Brian
PostPosted: Thu Nov 29, 2012 7:19 pm
Country: Romania
Thanks. After a few seal coats the leftovers are not really visible. The wood is yellow/orangeish too and figured (light flames and interlocking) which helps as well. The worst visual issues I ever had were with leftover CA spots from pore filling. They were visible under the seal coats but i thought more coats will make them vanish, but no. I had to wash it all off and sand.
Build log
Users browsing this forum: Powdrell1 and 22 guests
