It is currently Fri Aug 01, 2025 7:10 am
PostPosted: Sun Dec 02, 2012 3:23 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
I am building my first acoustic, and I have a set of radius dishes which I made like 12 years ago, 14' and 25', 2 of each, made from 3/4" MDF (machined) with a 3/4" plywood backer.
My question is what would be the best and quickest way to seal these. I will be attaching strips of Klingspor 80 grit PSA to sand the linings, and I don't want to waste it trying to attach it to bare routed MDF, if it won't hold.
I am thinking a quick spray with a can of automotive clear cellulose would work, but there may well be better options. I had envisioned previously that gluing a vertical grade plastic laminate to the MDF would be a great idea, but I don't have the time to experiment any more, I need a quick and dirty fix which will work for this one guitar.
TIA
PostPosted: Sun Dec 02, 2012 3:32 pm
How about a few wipes of shellac. I think that's what Shane Neifer uses on his...
PostPosted: Sun Dec 02, 2012 3:44 pm
The auto finish will work fine. Shane's uses Verithane wipe on poly.
Anything that will seal it will work fine.
PostPosted: Sun Dec 02, 2012 3:51 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Thanks guys, automotive cellulose it is (I don't have any shellac in the shop at the moment)
Just FTR, I reckon that the ideal surface would be vertical grade plastic laminate, cut in a 24" dia circle, with stopped radial slots (cut with an angle grinder) which would allow it to conform to the radius of the dish.
Contact cement and a J-roller, job done..
PostPosted: Sun Dec 02, 2012 5:56 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Be prepared, it's like trying to seal a sponge IMHO.
Kevin Looker
I'm not a luthier.
PostPosted: Sun Dec 02, 2012 7:25 pm
I made mine from birch plywood and sealed with two coats of some polyurethane I had sitting around.
PostPosted: Tue Dec 04, 2012 9:50 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I brushed mine with some watered down Titebond.
Good judgement comes from experience. Experience comes from poor judgement.
Users browsing this forum: ballbanjos, Bing [Bot], DennisK, Gary Davis and 34 guests
