It is currently Mon Apr 27, 2026 4:34 am
PostPosted: Fri Dec 07, 2012 10:28 am
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
So.... I'm working on an acoustic guitar for myself - and somehow had a brain malfunction.
I drilled the K&K pickup jack hole with a 3/4" bit instead of the intended 1/2" bit. oops_sign wow7-eyes gaah
I figure I'll plug the hole - but now I need a larger washer to cover up the hole. So... where can I get a washer that is a little bigger than 3/4" in diameter with a 1/2" hole? And while we're asking for it - I'd like it in Gold if possible.
The guitar has already been "finished" - so I can't just redo the end graft/wedge. I have to come up with a workable solution for a post-finish instrument.
Any sources you can tell me about would be GREAT.
This kind of fun for ONE STINKING WASHER!!! [uncle] [uncle] [uncle]
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Dec 07, 2012 10:48 am
First name: Tom
Last Name: West
State: Nova Scotia
This may be a job for your machinist friend.................! Stainless steel washer with a high polish. You may be able to make a tool from 1/2" drill rod and a small tool bit to remove material for a pearl washer inlay. Sorry to hear About your problem,hope you find a cure.
Tom
PostPosted: Fri Dec 07, 2012 11:40 am
Last Name: O'Melia
City: Huntsville
State: Alabama
http://www.mcmaster.com/#standard-flat-washers/=khnppi
This is a start... nickel plated brass washers
Look at this one: Nickel-Plated Brass Flat Washer 5/16" Screw Size, 3/4" OD, .05"-.08" Thk
Mount it between two pieces of wood, and use a hole enlarging bit to make ID 0.5"
Sorry, I saw no gold ones.
BTW Paul, I believe that qualifies for the the Dufus Award. laughing6-hehe
PostPosted: Fri Dec 07, 2012 11:49 am
Are there no plating services in your area? You could get a machined washer plated easily enough. Lots of those places around here.
OR...consider using Brass instead, and spray it with some lacquer. It's relatively easy to machine too.
PostPosted: Fri Dec 07, 2012 12:43 pm
Cap your plug with something to match/complement you binding and you have a design feature...
PostPosted: Fri Dec 07, 2012 12:48 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Ebony binding - maybe I'll just make my own wood washer out of Ebony.
Spray it with some poly - and see how it looks.
Still looking for other ideas.
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Dec 07, 2012 1:13 pm
This is what I would do. Or, alternatively, cap it with a piece of pearl or whatever you used for position markers.
I don't see any other way around it. You might find a washer the size you're looking for, but finding one in gold is gonna be "fun", IMHO.
PostPosted: Fri Dec 07, 2012 4:05 pm
Make one, shaped like your tailwedge but 1/4 scale, from 1/16" plate brass. Center a 1/2" hole. Polish to 2000, then buff & lacquer.
Or, make a duplicate trussrod cover (if you're using one).
In other words, turn mistake into a design feature.
Milton, ON
PostPosted: Sat Dec 08, 2012 1:04 am
First name: nick
Last Name: dingle
What about swapping the endpin jack for one of those ones with a screw in collar around the barrel? They are quite cheap, and come in gold......I bought one for a project that may or may not ever happen, given my current rate of production....
PostPosted: Sat Dec 08, 2012 10:11 am
Last Name: Burner
City: Lincoln
State: Nebraska
Nick - I don't know the style you are talking about. Can you provide a link or photo please?
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Dec 08, 2012 4:58 pm
Last Name: Burner
City: Lincoln
State: Nebraska
So - I'm not sure which is worse...
Posting on the OLF you've made an idiot move and asking for help or.....
Realizing that you really DIDN'T have a problem at all and cried wolf?
So..... here's the story.....
When I was installing the K&K I had glued the sensors in - and then started to put the jack in the hole. I unscrewed the end cap and thought - HOLY CRAP THAT IS SO SMALL - I DRILLED THE HOLE WAY TOO BIG!
So... knowing that the end pin is 1/2" I just "assumed" based on the size of the threaded jack that I had drilled the hole with my 3/4" bit.
I went to the hardware store and bought some 3/4" dowel to plug the hole. Brought it home and held it to the hole and realized that the dowel was HUGE compared to my hole.
So.... I went back and looked at things and had totally forgotten that the end jack is 2 different sizes. It steps down to a smaller size for the end cap on the outside of the guitar - but the main shaft is bigger. See photo.
So... end of the story is I get double embarrassment because everything is OK - and I have to admit to the world that I am a double bozo! laughing6-hehe laughing6-hehe laughing6-hehe
End of the story is all is well in Nebraska!
P A U L B U R N E R
Burner Guitars
PostPosted: Sat Dec 08, 2012 4:59 pm
First name: Tony
Last Name: C
City: Brooklyn
Ha. Ha. Ha.
At least you didnt mess up!
http://www.CostaGuitars.com
PMoMC
PostPosted: Sat Dec 08, 2012 5:03 pm
Well, yes, now this little slip up has been logged in cyber-space for all posterity. Not a big deal. I've done sillier things myself.
The good news is that you haven't wrecked your guitar and can move forward.
PostPosted: Sat Dec 08, 2012 5:04 pm
First name: Ron
Last Name: Belanger
I like the ebony washer and perhaps a line of bwb purfling around the outside to show it off. [:Y:] [:Y:]
PostPosted: Sat Dec 08, 2012 7:22 pm
Don't worry Paul. Your secret is safe with us. ;)
PostPosted: Sat Dec 08, 2012 9:26 pm
First name: Tom
Last Name: Rein
City: Saline
You could always go with a D-Tar Lock-'n-Load, which has the batteries accessible through the endpin. I think this is actually a better system than the bag attached with velcro inside the guitar. I have not used the system since it uses a bigger hole than standard, but you are already there!
Stay with the happy people.
--Reynolds Large
PostPosted: Sat Dec 08, 2012 9:48 pm
The obvious fix is to make the hole even larger and call it a sound port.
It's your guitar...who can argue with you?
Install the pup jack in lower bout (with properly sized hole).
Or...ebony plug, drilled out to proper size. Will be a thin black circle when you're done, and people will think you're a magician.
PostPosted: Sun Dec 09, 2012 4:57 am
First name: Tom
Last Name: West
State: Nova Scotia
Paul: Your an awful brave man..................................!!!!!
PostPosted: Sun Dec 09, 2012 5:54 am
First name: Trevor
Last Name: Gore
City: Sydney
Todd Stock wrote:
The end pin hole size on a K&K is 15/32" - 1/2" will be a fairly loose fit...
I know some of you guys are going to find this hard to comprehend, but the rest of the world thinks it's 12mm. ;) :lol:
http://www.goreguitars.com.au
PostPosted: Sun Dec 09, 2012 7:39 am
Hey...no causing trouble here. We obviously have enough troubles without adding that metric crap into the mix...
beehive
laughing6-hehe
PostPosted: Sun Dec 09, 2012 9:36 am
Last Name: Burner
City: Lincoln
State: Nebraska
I don't care who you are - that's funny!
P A U L B U R N E R
Burner Guitars
PostPosted: Sun Dec 09, 2012 11:47 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
We're a metric nation as well, but I never made the change-over. When I talk inches, feet, yards, mph, my kids look at me like I'm an idiot. duh
Alex
PostPosted: Sun Dec 09, 2012 1:55 pm
First name: Mark
City: Concord
Paul Burner wrote:
.. and I have to admit to the world that I am a double bozo! laughing6-hehe laughing6-hehe laughing6-hehe
We've all ridden the Bozo Bus. Welcome to the club...just don't sit on the Dwarf [:Y:]
PostPosted: Sun Dec 09, 2012 4:01 pm
I care...to quote Luke Skywalker.
PostPosted: Mon Dec 10, 2012 3:29 pm
Just did an install of a Baggs system in a Taylor that was equipped with their ES system. Customer supplied this:
http://www.truplugusa.com/
The end plate may be just what you need. [:Y:]
