It is currently Wed Aug 13, 2025 6:16 am
PostPosted: Wed Feb 27, 2013 2:23 pm
First name: Dean
Last Name: Heard
City: Bournemouth
State: uk
Zip/Postal Code: BH1 4ED
Country: England
Hay all, what is the best router bit for a rosette?????
PostPosted: Wed Feb 27, 2013 2:39 pm
Last Name: Kincheloe
1/16" spiral downcut end mill.
PostPosted: Wed Feb 27, 2013 5:27 pm
Unless you're adding a purfling line of 1/32"...... ;)
If all your doing it routing out a channel on the top to install a basic wood rosette, I'd go with either a 1/16" or 1/8" end mill.
As Dennis said though, you'll want to go with a downcut spiral.....Stew Mac sells them (rather expensive) or you can get them from places like MSC. Or do a search on the forum for small end mills and you should get several hits with where to purchase inexpensively.
it depends on the rosette.
A sharp bit. I won't use a down cut on a closed cut , the chips are pushed into the work . This creates more heat. .I use 3/32 bits for most of the rosettes. I also use a 70,000 rpm cutter.
PostPosted: Thu Feb 28, 2013 11:01 am
First name: Dean
Last Name: Heard
City: Bournemouth
State: uk
Country: England
Thanks for your help and advice guys!!!!
Something for nothing was never dear!
PostPosted: Thu Feb 28, 2013 1:35 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I've thought this too. I use straight router bits and never had a problem with my laminate trimmer.
I'd use the biggest bit you can for your rosette. I try to make one pass to remove most of the wood and one to fine-fit. Fewer passes meas fewer chances to screw it up
Users browsing this forum: Ken Lewis and 28 guests
