It is currently Tue Nov 25, 2025 2:47 am
PostPosted: Fri Jan 11, 2013 10:23 pm
First name: Victor
Last Name: Seal
City: Osseo
Zip/Postal Code: 49266
I am going to purchase a binding router jig. I have been looking at all of them I could find on the web. Before I buy one I would like to have input from the OLF. Your preference and why? Pals, Vic.
PostPosted: Fri Jan 11, 2013 10:45 pm
Take a look back a few weeks. There was a tread that talked about different setups.
For what it is worth I use a Luthier Tools Router Base.
Pro's.
- It is small and packs away in a drawer which is really important in my shop where space is limited.
- Since it used a spiral router bit it can be adjusted to any depth of cut. (no follower bearings)
Con's
- The weighting of the tool is a little screwy so it is easy to screw up. This can be easily fixed by making a counterweight on the opposite side of the router. I have not done this yet but done right would make the tool pretty good.
Most people seem to like the the various designs where the guitar body is set in a cradle (ie Williams Jig or Robikie (sp?) style. They work well but require lots of room to store the jig when not using and require a little more setup.
I have seen the Mark Kent designed jig which indexes off the side of the guitar and works very well. I saw a variation of this design being used in the Taylor factory. It was out of production for a while but someone recently started selling the model again.
Good luck!
Brad
Avon, OH
PostPosted: Fri Jan 11, 2013 10:52 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Newbie here. I built the Williams/Fleischman jig and it works great. As has been mentioned, it is a bit bulky but it is very easy to use.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sat Jan 12, 2013 7:51 am
State: ON
I'm the guy Brad mentioned who has brought the Kett jig back into production. As he said there was a lot of discussion around this a few weeks back.
Here is one of the links http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=38581
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sat Jan 12, 2013 8:40 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have used a Luthier Tool router base, a StewMac tower and a Fleischman jig.
If one is very careful with the Luthier Tool base and develop a technique to keep the tool from tilting in, it is a very nice tool because of the precision adjustment of the cut vs. relying on bearings.
I liked the StemMac tower because it held the router square, I placed mounting t-nuts in my bench so it was easy to remove the tool and put it in a drawer. The con I had with this tool was that I really needed to attend to the router with one hand (it is not counter balanced) and the feed the guitar on a carriage into the router with the other. I never really felt the secure using the tool. I did have good results on four instruments.
I finally made room (my only con for this tool so far) and bought a Fleishmann binding jig from John Hall at Blues Creek guitar and found it a dream to use. I can clamp the carriage holding the guitar down and then securely and calmly guide the router around the guitar.
PostPosted: Sat Jan 12, 2013 10:31 am
Williams from John Hall.
PostPosted: Sat Jan 12, 2013 10:38 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
I just built a tower that uses the Stewmac bearing set.
Here's my sophisticated counter balance.
And here's the donut that I made from a piece UHMW plastic on my wood lathe.
I've only done 1 guitar with it but love it so far. [:Y:]
Kevin Looker
I'm not a luthier.
