It is currently Fri Aug 15, 2025 12:12 pm
 Post subject: Heat blanket burn out...
PostPosted: Thu Jan 17, 2013 12:43 am
Can you burn them out? I've lost 7 sides in a row using standard practice, different species, random spots. About 6 months ago, the timer/router controller stopped working, so I've been plugging the blanket straight into the wall. Sometimes it takes forever to get to temp, sometimes faster, sometimes going backward a while before getting hotter again. I also think it has hot/cold spots. Do these things pooch out? I doubt if I've even bent 70 sides since getting it about 2 1/2 years ago....
PostPosted: Thu Jan 17, 2013 8:00 am
They can . Get a controller , as these things can spike to 450 degressF. I burned 2 up in 8 years. The blanket didn't burn up the cord failed. I will not use Full power more than a few minutes.
Not all blankets are created equal, some are only 2 1/2 watts per inch . I use 5 watts per inch. Early in my days I tried a 2 1/2 and it didn't last long and at that time I was bending thicker than I should. It lasted less than a year. Been using 5 watters ever since. With a little care they should last you a long time.
Simple rules to follow for caring of the blanket
1 don't fold it. I keep mine in my machine when not in use
2 don't over heat it. Use a controller
3 avoid light dimmer switches they use a resistor , this lowers the voltage and makes the blanket work harder and will burn them up much like a low voltage to a motor.
4 Keep an eye on the plug wire getting bare spots.
5 don't run on Full power more than 6 min .
PostPosted: Thu Jan 17, 2013 10:54 am
Most cheap dimmers use a chopper circuit to reduce voltage ... the peak is still 120V, but the sine wave is chopped up into intervals to give a lower RMS output .... a resistor would get way too hot and need to be rated at a high wattage - not practical.
I have been using a 2.5 watt Omega blanket with a cheap HD dimmer for almost ten years now .. still working fine.
PostPosted: Thu Jan 17, 2013 10:55 am
John - by 'controller' you mean a PID with a servo switch (on/off voltage) type setup?
PostPosted: Thu Jan 17, 2013 6:24 pm
Last Name: Beaver
City: Lake Forest
In my experience most of those crazy temperature fluctuations are do the temp reading apparatus. I am forever cautious so I use water as an indicator. (look for steam, listen for water sizzle and drop a little water on the slats to see what it does)
Joe Beaver
Maker of Sawdust
Users browsing this forum: Powdrell1 and 15 guests
cron
