It is currently Mon Apr 20, 2026 7:03 am
PostPosted: Tue Jan 22, 2013 6:18 pm
First name: Sean
This may be a silly question, but I have a couple of aerosol cans of color tone spray lacquer colors that I was planning on trying a sunburst finish with, when I started to wonder...can you spray a water based lacquer over this?
The cans are nitro based from stewmac, and my finish is Ktm 9.
Thx for the feedback in advance.
Sean
change isn't synonymous with improvement
instagram.com/bucketguitars/
PostPosted: Wed Jan 23, 2013 7:49 pm
Last Name: Beaver
City: Lake Forest
Since no one seems to have an answer, let me try.
I'd test on a scrap first. Spray the colored nitro, let it dry until no more off gas odor (probably a week or two. Next I would spray half the sample with a de-waxed shellac like zinsser primer sealer. Let that dry and then coat both pieces with the waterbased. I'd bet the shellaced piece will work fine.
Good Luck
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jan 24, 2013 6:08 am
First name: Sean
Thx Joe,
I'll try that.
PostPosted: Thu Jan 24, 2013 8:07 pm
Last Name: Beaver
City: Lake Forest
As I suspected, the nitro guys have an aversion to anything waterbased. beehive Someday perhaps a finish will come along that will set them free bliss
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jan 24, 2013 8:59 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Not really so, I have tried a lot of different finishes. Haven't found any that do better than Nitro or FP for guitars. Floors, cabinets, furniture, boats..........are far different items with different needs. I just have no idea if you can run a particular urethane over nitro. For a new finish I would choose one system and use it the whole way through. Adhesion and film bond problems may take a while to manifest, it may fog or peel. The lacquer will still be trying to outgas under the other coating.
Brian
PostPosted: Thu Jan 24, 2013 9:35 pm
First name: Sean
That's a good point, Brian. I think I will stay with one, water based, and just spend some more money on some dye I can spray with my hvlp gun. I'm getting nervous about using cans anyway. There's no control.
Thanks to both of you for replying.
Sean
