It is currently Mon Aug 18, 2025 2:45 am
PostPosted: Wed Feb 13, 2013 7:28 am
First name: David
Last Name: Schneider
City: Silvis
State: IL
Zip/Postal Code: 61282
I have a Martin guitar that has been droped and the back has come loose from the side. It is made from High Pressure Laminate not wood. Does anyone know what is the right glue to use?
PostPosted: Wed Feb 13, 2013 8:27 am
It was a special Adhesive. I have used med Superglue with success.
PostPosted: Wed Feb 13, 2013 4:26 pm
How 'bout bonding Richlite to HPL? I asked you this at Woodstock, but if I recall correctly, you thought there was another adhesive recommended by Martin for this purpose but you weren't quite sure of the name at the time? (BTW: It was a pleasure meeting you)
PostPosted: Wed Feb 13, 2013 7:27 pm
If the HPL guitar has a wood lining to provide some gluing surface then you can use titebond to glue things back together. Lightly scuff the HPL gluing surface as you would wood to provide a fresh surface for gluing. You can also use CA or epoxy, but yellow glue will work.
I have glued richlite to richlite using a two part epoxy. If you are gluing to formica you might want to scuff the surface to provide some "tooth" for the epoxy to grab onto. The finished side of HPL can be pretty slippery, so it might be hard to get a good bond to it.
PostPosted: Wed Feb 13, 2013 7:47 pm
the glue Martin uses is a 3m product Call me and I can tell you the part number.
PostPosted: Wed Feb 13, 2013 10:33 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
Give this glue a try......... we love it. We use this a lot on rosettes..... ( also works great if you have a wood welder ... activates and holds almost instantly. http://www.workriteinc.com/)
RooGlue
http://www.rooglue.com/rooclear.html
Blessings,
Kevin
