It is currently Sat Aug 09, 2025 11:48 am
 Post subject: Abalone purfling
PostPosted: Thu Apr 04, 2013 3:34 am
I used the cutting described by Chris Paulick in his you tube video and it worked quite well for my rosette.
Now I am getting to the purfling and he has another video about that. He just uses straight pieces for the whole job. Other videos I have seen use straight pieces as well. Does this really work with no gaps in the joint where the pieces break?
I was thinking of cutting the various curves using the above mentioned jig. Does anyone do this also?
Also how do the straight pieces work on the tight radius of a cutaway?
 Post subject: Re: Abalone purfling
PostPosted: Thu Apr 04, 2013 9:20 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
With a little mitering with a file on the real tight bends and just breaking into place in the straighter areas the joints are pretty much invisible after finish is applied. I always try to find pieces that blend together or even match as I work my way along as it also improves the look.
Fred
Fred Tellier
PostPosted: Thu Apr 04, 2013 1:53 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
When purfling my ukuleles I like to have the curved as well as the strait on hand.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Thu Apr 04, 2013 4:57 pm
I was thinking of making curved pieces close to the radius of the various curve. Is this over kill?
PostPosted: Sat Apr 06, 2013 9:10 pm
Last Name: Smith
City: Graton
If I understand you correctly, yes that would be over kill and a waste of time. Just make one curve a little less than your average curve.
Michael F Smith
Goat Rock Ukulele
