It is currently Thu Jul 31, 2025 11:17 am
 Post subject: Fan Fret Head HELP!
PostPosted: Tue Apr 16, 2013 8:44 am
First name: George
Last Name: Heatley
Country: United Kingdom
Hey everyone
I'm just about to start my first fan fret and a couple of things are confusing me haha.
I thought I would build a mock neck to see if what I was thinking was right.
My problem is the scarf joint...
So I cut the scarf joint, glued up, marked the angle at the nut that i had calculated.
Usually with a perpendicular nut this isn't a problem as i would plane down the head to achieve a flat face for veneers to be glued to in which case as my necks are planed flat and square before hand, once i have achieved a flat face on the head it will still be square to the edge.
With the fan fret, i marked the angle and planed down the head with the blade of the plane perpendicular to the angle i had marked if that makes sense.
So I'm left with this
I got the face flat and then realised its no longer square to the edge.
Is this right????
I usually thickness the head from the back so i can't see that being a problem but i just wonder if this how it should be and if other people do it like this?
I don't know if i have written this in a way that will make sense but hopefully it does haha.
Any help appreciated, George.
 Post subject: Re: Fan Fret Head HELP!
PostPosted: Tue Apr 16, 2013 9:06 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Make the back of the headstock parallel with the top and continue. I shaped my outline square to the face and it is fine, this is one of the joys of building a fan fret. I spent a bit of time trying to visualize how locate the tuning machines to look good. I had to compromise a bit on the headstock shape due to case length constraints.
Fred Tellier
PostPosted: Tue Apr 16, 2013 10:12 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
If you think about it, it couldn't do anything else. If the top was perpendicular to the sides, you would have put a twist in the face and the veneers wouldn't lie flat.
Pablo Picasso
PostPosted: Tue Apr 16, 2013 12:58 pm
Yep, that's how it works. As long as you still have enough thickness on the thin side of the headstock, you're fine.
http://www.chassonguitars.com
PostPosted: Tue Apr 16, 2013 1:15 pm
Last Name: Kincheloe
That's how I do it.
PostPosted: Wed Apr 17, 2013 5:04 am
First name: George
Last Name: Heatley
Thanks guys...
I thought it was right but I was doubting myself at the same time.
I think once the head shape is done it isn't noticeable hence why I have never noticed it on a fan fret guitar before.
I measured the angle and it was still 15 degrees at every point across.
Should have plenty there to thickness the head still.
George
Users browsing this forum: Bing [Bot] and 15 guests
