It is currently Fri Aug 01, 2025 7:52 am
PostPosted: Tue Apr 16, 2013 4:17 pm
City: Alton
State: IL
I've narrowed it down to two options.
1.) Lacquer guitar finish with z-poxy finish
Pros:
I am currently in possession of everything needing to do a Lacquer finish.
Lasting duriable finish
Easier than the French Polish
Cons:
If I put the finish on two think, it will kill the sound
2.) French Polish
Pros:
Looks great
Sounds great
Cons:
Need to buy stuff.
Also, need to learn how to do it.
Any suggestions? Opinions I also thought briefly about an oil finish. I do a lot of oil finish on my furniture builds, but picturing those finishes on a guitar... it doesn't work in my head.
PostPosted: Tue Apr 16, 2013 4:48 pm
First name: Larry
Last Name: Hawes
That's a pretty slim, single con for the lacquer finish - millions of great sounding guitars out their with a lacquer finish and the pros seem to outweigh the cons. Is it your last guitar? If not go either way and learn a new skill no matter the finish.
Thank You and Best To All
PostPosted: Tue Apr 16, 2013 5:16 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
You have to put a lot of lacquer on to get it too thick, There is lots of information available on both methods. Lacquer is a bit more durable and if done well they both look real good.
Fred
Fred Tellier
PostPosted: Tue Apr 16, 2013 5:44 pm
Try the liquid hard shellac diluted with 100% DAA. You can spray it on. Drys almost immediately and hardens besutifully in 20 days via a polymer additive. Literally designed for musical instruments. It's from down under but available in US. Brand is called Ubeaut I believe.
PostPosted: Tue Apr 16, 2013 5:59 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Do you have first hand experience with the Ubeaut product? I have heard some not so nice things about it but none from the first person.
Brian
PostPosted: Tue Apr 16, 2013 6:39 pm
First name: Trevor
Last Name: Gore
City: Sydney
I know the guy who "invented" it and licensed it to Ubeaut. The original formulation had a plasticising agent in it, which Ubeaut, in their wisdom, wanted out. That resulted in finishes crazing as they hardened. So, in their wisdom, Ubeaut put it the plasticiser back in, and now, apparently, everything is fine. I haven't used the Ubeaut stuff, preferring to get mine straight from the "inventor" who lives a few suburbs away. It works brilliantly. I originally tested it out on a kitchen bench, which is still going strong ~10 years later, which is pretty good for FP on a kitchen bench. Most of the guitars pictured on my website have tops FP'd with this product. Never a problem for me. I'd say it wears at least as well as nitro and quite a lot harder than your typical shellac. I've never tried spraying it. I want to call my finishes French polished rather than shellacked.
http://www.goreguitars.com.au
PostPosted: Tue Apr 16, 2013 7:45 pm
I have a good friend who is a fine classical builder, here in NC, and he is using Ubeaut. He likes it a lot. He sprays several coats for the spit coat before beginning the FP process. He said it gives him a much better base and keeps things from going splotchy. He did say that he has to be very careful when spraying as the solvent is some bad stuff vs local alcohols, and if he breathes any of it he has problems for days. He is also very careful, when using it for FP, to have good ventilation.
PostPosted: Tue Apr 16, 2013 8:01 pm
Last Name: Howard
City: Magnolia
State: Delaware
Thanks, good to know. I will still use buttons for all my FP though, that stuff is tough.
Brian
PostPosted: Tue Apr 16, 2013 10:53 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I French Polished a classical guitar with ubeaut (the second formula) a couple of years ago. It acted like shellac through the process. I diluted 50% with DA. Also I used almost no oil through the whole process. The finish still looks good.
