It is currently Sun Sep 21, 2025 6:18 pm
 Post subject: Removing plates...
PostPosted: Thu Apr 18, 2013 1:25 am
I need to remove the top and back from a guitar I'm working on. I've had limited succes before with this. I'm okay around the edges, but how do you get it off the blocks without opening up the center seam? I have difficulty with that....
 Post subject: Re: Removing plates...
PostPosted: Thu Apr 18, 2013 6:34 am
Heat
I guess you knew that already but at the blocks I use a thin knife ( a pampered chef icing knife ) and a candle to heat that . You can heat the knife and work it into the joint , there is a knack but you will figure that out pretty quick
PostPosted: Thu Apr 18, 2013 9:14 am
I've been applying the iron directly to the wood around the edges. You're saying to heat the knife instead?
PostPosted: Thu Apr 18, 2013 11:21 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Generally applying the iron directly to the wood directly over the blocks will cause the center seam to separate as it releases from the block making more repair work in the end. Like John says heat the knife. I have a selection of artist pallet knives that are stainless steel and work well for this.
Brian
PostPosted: Thu Apr 18, 2013 11:49 am
That will just shrink the wood, probably never to return to it's original state. Learned that lesson many years ago.
PostPosted: Thu Apr 18, 2013 12:13 pm
Could explain a thing or two...
PostPosted: Thu Apr 18, 2013 10:42 pm
Womp! Womp! Womp! (descending trombone!)
Epic fail, again. Jokes on me...
PostPosted: Thu Apr 18, 2013 11:22 pm
Todd Stock wrote:
Why are there pampered chefs, but no pampered luthiers? Life really is gloriously unfair.
Wait, are implying I was taken when I bought my Pampered Luthiers Knife? I did pay twice as much as the Pampered Chef knife that appeared to be the same, but I figured this had to better, it's for luthiers after all!
PostPosted: Sun Apr 21, 2013 8:05 am
Todd,
To do pampered luthiers you first have to invite your luthier friends over to drink beer and smoke cigars and then trot out a lot of overpriced specialized tools that have limited uses, but are very nicely made and work well for what they do. Lie Nielsen and Stew Mac might be happy to oblige, as well as a few others. [:Y:]
PostPosted: Wed Apr 24, 2013 9:20 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
If it's hide glue, even unheated knife will break the glueline if you're careful enough.
I heat the knife in a torch or alcohol lamp and slowly work my way around the body, if PVA is used. Be extra careful around the blocks.
Typhoon Guitars
Users browsing this forum: Gasawdust and 56 guests
