It is currently Tue Aug 05, 2025 7:46 am
 Post subject: Rounding the saddle
PostPosted: Thu May 02, 2013 8:35 pm
First name: Maks
Last Name: Lavrov
How do you guys do it? After routing out the slot, the slot has perfect half circles at the ends and I want the saddle to match perfectly. Also, I use a 1/4" saddle and my bit is the same size down spiral. Slot comes out perfect, but the saddle doesn't sit in there tight. It's not loose by any means but not snug and falls out if flipping the bridge. Is there a quick fix for that?
 Post subject: Re: Rounding the saddle
PostPosted: Thu May 02, 2013 8:53 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I get the saddle ends close on the disc sander & finish with files & sanding blocks.
If you need to add a tiny bit of thickness to a saddle, a thin coat of super glue can do the job.
PostPosted: Thu May 02, 2013 9:00 pm
I thickness sand my saddles to the slot using my Performax. Until they slip in with some pressure, then I shape them, and by the time I polish them, they are the exact right fit.
Old growth, shmold growth!
PostPosted: Thu May 02, 2013 9:20 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Why not make a sanding guide if sorts. Cut a half slot in a piece of wood just like the saddle slot but oversize enough to compensate for sandpaper. Glue sandpaper in the curved end of the slot. Now you have a 1/8" radius sanding block for sanding the ends of the saddles.
It is worth a try.
PostPosted: Thu May 02, 2013 10:04 pm
First name: Maks
Last Name: Lavrov
Todd, where can I find oversized blanks? The widest ones I've seen are these 1/4" blanks.
PostPosted: Thu May 02, 2013 10:27 pm
First name: Larry
Last Name: Hawes
Apparently 1/4 = 6.35 mm - so if you could find a 6mm bit, route your slot, then sand/thin the saddle to fit?
http://mdmetric.com/tech/cvtcht.htm
Here's one.
http://www.woodworkerswholesale.com/6mm ... x01308.htm
Thank You and Best To All
PostPosted: Thu May 02, 2013 11:12 pm
First name: Trevor
Last Name: Gore
City: Sydney
LarryH wrote:
Here's one.
...but you'll need a 6mm collet for that particular one.
6mm ones with 1/4" shaft are available tho', just got to find them. I prefer doing three cuts. One to get the bulk out and then two more to clean up the front and back sides. You need a precision router/jig to do it though, so that you finish where you want. But 3/16" bits are easy to get...
http://www.goreguitars.com.au
PostPosted: Fri May 03, 2013 5:48 am
Could you just make shaving with your plane and glue it in the slot?
Sent from my GT-P3113 using Tapatalk 2
Under Compensated Nut!
PostPosted: Fri May 03, 2013 2:45 pm
First name: Maks
Last Name: Lavrov
Thanks a lot for the replies guys!
PostPosted: Sat May 04, 2013 2:18 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Put a coat of CA on both sides of a loose saddle.
Apply excelerator.
then fit it carefully again.
After sanding the ca down.
Measure with dial calipers the width of the saddle
blanks if you buy them.
They usually are not all the same measurement.
Mike Collins
Users browsing this forum: jfrench and 50 guests
