It is currently Mon Aug 04, 2025 8:08 am
PostPosted: Wed May 15, 2013 3:50 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
It's not really "dead" sounding, but doesn't ring as well as the other strings, mostly when fretted. I think it's okay played open. This guitar has been strung up for about 3 weeks. I just did the second setup. Ended up making a new nut because I had a few low strings in the nut slots. The owner didn't mention anything about the 6th string when we talked about the new setup, and I don't remember thinking it sounded muddy when I first set it up.
Any ideas or suggestions? Anything I should try or could do?
THanks, Beth
PostPosted: Wed May 15, 2013 5:07 pm
First name: David
Last Name: Malicky
Zip/Postal Code: 92111
That's not uncommon on smaller bodies. Possibly the 'main air' frequency is a bit high. Can you measure it?
David Malicky
PostPosted: Wed May 15, 2013 5:08 pm
Beth, you could try a new string first.
Easy experiment at least.
PostPosted: Wed May 15, 2013 8:10 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
The strings are new. I haven't learned yet how to measure the main air frequency (I'll do a search or look for it in Trevor's book). Patience I can do.
Thanks guys
PostPosted: Thu May 16, 2013 8:19 am
You may want to check that the fret ends are well seated. If not, it would explain why the tring sound dead when fretted.
On one of my first guitars, I didn't quite master my fret installation technique, and didn't notice that all the fret ends where just shy of being completely seated. Once I noticed I had to superglue all of them one by one to solve the problem.
Alain Moisan
(Now building just for fun!)
PostPosted: Tue May 21, 2013 11:06 am
This might be a wolf note. If so it can be fixed. Check out Alastair Fordyce's article in the GAL journal.
PostPosted: Tue May 21, 2013 12:19 pm
what different brands and types of strings have you tried?
PostPosted: Tue May 21, 2013 1:49 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I was thinking this might be the answer, but it seemed better after a couple days post- setup (hopefully Todd was right and just a bit of time and playing will see it right).
The strings used by the musician are Elixer medium gauge.
PostPosted: Tue May 21, 2013 3:48 pm
Last Name: Killin
Beth,
I'm new to setup so take this for what it is worth. I had some initial muddy\dead sounding strings on mine when I set it up and ended up widening the nut slots just a bit to bring them back to life. Since you changed the nut, this could be it. Of course I could be totally wrong. laughing6-hehe
Also, on that same guitar i recently moved from a D'Addario Med string to an Elixir Med string and it overall has a muddy sound. gaah I'm going to try switching back to see if it improves, but I might work the nut slots a bit to see if I can get a better fit with the Elixirs. They might be just a bit tight. Either way I don’t think I’ll be putting on another set of Elixirs.
Good luck,
PostPosted: Tue May 21, 2013 4:41 pm
First name: EddieLee
Last Name: Brown
Notes on the Low E string of my OM suddenly got much stronger about 4 to 5 weeks in. So I guess I am +1 for Todd's comment.
_____________
EddieLee
Users browsing this forum: meddlingfool and 10 guests
