It is currently Sat Aug 02, 2025 3:41 pm
PostPosted: Sun May 19, 2013 2:05 pm
City: Calgary
State: Alberta
What glue for bone to Indian rosewood? The bone inlays on my tie-blocks keep on popping off with only slight force applied to them. I've used Titebond Original and I'm sure the glue is good.
PostPosted: Sun May 19, 2013 2:24 pm
First name: Ringo
superglue or epoxy.
PostPosted: Sun May 19, 2013 3:27 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
And Poly !
Mike Collins
PostPosted: Sun May 19, 2013 3:42 pm
City: Calgary
State: Alberta
The glue stuck to the rosewood, but appeared to not stick to the bone, which surprised me. The bone is quite dense and smooth and the surface is not porous. I think I'll clean the old titebond off as well as I can and use epoxy next time.
Do other people have problems with titebond in this application?
PostPosted: Sun May 19, 2013 3:50 pm
Last Name: Collins
City: Argyle
State: New York
I would not use Titebond for bone to wood gluing.
As stated before-CA, Epoxy, or Poly.
Mike Collins
PostPosted: Sun May 19, 2013 4:07 pm
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Out of ignorance, I used Titebond II for everything on my first two guitars (both classicals) and have had no problem with the bone on the tie-block of the bridges. I did, however, wick in some CA to fill gaps, and maybe that's why I had no problem.
PostPosted: Sun May 19, 2013 4:54 pm
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have used Duco cement for stuff like this with good results...Mike
PostPosted: Sun May 19, 2013 5:30 pm
Hide glue sticks Bone very well. All those fancy 19 th century instruments smothered with MOP or Ivory.
PostPosted: Sun May 19, 2013 6:24 pm
City: Calgary
State: Alberta
I assume fish glue would be OK? I still have no idea why titebond did not grab onto the bone.
PostPosted: Sun May 19, 2013 6:30 pm
I've had problems with Titebond sticking to particularly smooth and hard bone pieces.
Old growth, shmold growth!
PostPosted: Mon May 20, 2013 9:14 am
First name: Rob
Last Name: Brown
City: Melbourne
State: vic
Zip/Postal Code: 3142
I recently did some bone work , I converted a cow leg bone into some escutcheons for some furniture and now have a decent stash of odd sizes for whatever else I may use it on. possibly build no 2 .
I was glad to have come across this link. It goes into why bone does not stick ,or comes loose
http://www.bearmeadow.com/build/materia ... clean.html
Rob
PostPosted: Tue May 21, 2013 8:23 am
Fish glue will work wonderfully, so will hide glue, which is no big surprise, as bone is a near relative... Make sure that both the bone and wood are freshly scraped, and that the surfaces mate well. Some pieces of unbleached bone can be difficult to glue, if there is still grease left. CA etc also works, of course.
PostPosted: Tue May 21, 2013 11:18 am
City: Calgary
State: Alberta
I used some epoxy and it appears to be holding well - although I haven't stressed tested it.
Thanks everyone.
Steven
PostPosted: Wed May 22, 2013 1:29 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I glued bone to ebony with CA, and the string pressure was still enough to pop the tie block off...
Typhoon Guitars
PostPosted: Wed May 22, 2013 4:53 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
In my experience, Titebond is not suitable for nonporous surfaces.
HHG works pretty well, but I still favor CA for gluing bone.
PostPosted: Thu May 23, 2013 8:25 am
I like CA as well for that application. I like to use AR glue for the nut though because it gives you a bit of time to wiggle it in place perfectly.
Users browsing this forum: Bing [Bot] and 28 guests
