It is currently Sat Aug 09, 2025 1:36 am
PostPosted: Tue Jun 11, 2013 10:13 am
Last Name: O'Melia
City: Huntsville
State: Alabama
So, all is well. Still need to fine tune the setup. But one issue has me baffled. I suspect it has to do with the saddle. The E, B, and A strings are a bit "muted". I'm using a uncompensated bone saddle (for now). Do I need a "sharper" edge on the saddle? (its rounded for now).
PostPosted: Tue Jun 11, 2013 2:04 pm
Round should be fine.
Maybe it's a bad set of strings?
Old growth, shmold growth!
PostPosted: Tue Jun 11, 2013 2:05 pm
Post a closeup picture.....
PostPosted: Tue Jun 11, 2013 2:49 pm
First name: Tom
Last Name: West
State: Nova Scotia
Mike: Have you considered it may be varying density in the bone saddle? I use a wide saddle and have not had a problem with amount of contact area as long as the string leaves the saddle at it's high point.
Tom
PostPosted: Tue Jun 11, 2013 3:52 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, I will post a pic tonight. Gonna stop by a local guitar shop and buy a couple of those synthetic, compensated bridges to test that theory.
PostPosted: Tue Jun 11, 2013 10:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ok. So I installed a tusq saddle. I do not like that material. I'd rather grind bone any day. But, that was not the issue. I discovered I had a nut seating problem. It was a bit lifted in the E A side. Got some of it fixed tonight and there was a marked improvement. Had to go to church band practice so I did not finish tonight. But it sounds MUCH better already.
