It is currently Wed Aug 20, 2025 1:31 pm
 Post subject: Guitar neck adjustment.
PostPosted: Mon Jul 15, 2013 3:45 am
First name: Ganasen
Last Name: Govender
City: Germiston
State: Gauteng
Zip/Postal Code: 1401
Country: South Africa
Hello fellow members. I am a keen person from South Africa wanting to start learning to get into guitar building.
How will a layman establish if the guitar neck needs adjustment?
How does a beginner learn to adjust the guitar neck?
Does this affect the sound of the guitar?
Does a person need to adjust the neck after every new string replacemnet?
Does the gauge of the strings affect the sound.
Should the strings be stretched whils't be inserted.
Excuse the questions as I am keen in learning from the professionals out there !
Gansen
:D :D :D :
PostPosted: Mon Jul 15, 2013 7:29 am
Some answers .....
The neck needs adjsutment if the relief (the amount of curvature in the neck)is too great or too little - one can easily check the relief by holding down one string (I usually use the low and high E) at botht eh first fret, and the fret nearest the neck joint, so on a typical acoustic that would be 15, and then seeing how much gap there is under the srting at the 7th fret. More than a business card and its too much .. no gap and thats usually too little.
next question .... same way one gets to Carnegie hall .. practice.
It doesnt.
No
Any string change can affect the sound of the guitar, even the same gauge by different manufacturers. generally I find heavier strings sound warmer, fuller. Thin strings sound thinner and weaker ...
Once installed, I stretch the string a bit .. helps them to setttle in and stay in tune whilst playing.
PostPosted: Mon Jul 15, 2013 11:25 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Same answers...
PostPosted: Wed Jul 17, 2013 6:20 am
First name: Ganasen
Last Name: Govender
City: Germiston
State: Gauteng
Thanks a millon Tony Karol.
There are so much advice and assistance I can get from member like you.
Thanks .....................
Ganasen South Africa :
D
8-)
:lol: :lol: :lol:
PostPosted: Thu Jul 25, 2013 7:57 am
First name: Ganasen
Last Name: Govender
City: Germiston
State: Gauteng
Hello fellow members being a novice and this is my first restoration & build project, I would welcome any suggestions and advice.
I have already sanded the guitar body and neck.
The glue holding the body together has since perished.
What sort of primer should I use .
what sort of varnish or paint should I spray on.
What should I use on the fretboard.
Should I remove the frets or not.
Excuse me for asking these question's if they sound funny,as I am a true novice and want to learn from the professional's out there.
Thanks folks
Keen South African Novice Luthier !
PostPosted: Sun Jul 28, 2013 10:14 am
First name: Rob
Last Name: Hope
City: Houston
Zip/Postal Code: 77070
Gansen,
if you haven't picked up "Guitar Making, Tradition and Technology" by Cumpaino, you need to . He outlines the adjustment of the neck process very well.
PostPosted: Tue Jul 30, 2013 8:09 am
First name: Ganasen
Last Name: Govender
City: Germiston
State: Gauteng
Where would I get contact details for Cumpaino ?
PostPosted: Tue Jul 30, 2013 8:25 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
http://www.cumpiano.com/
Alex
PostPosted: Tue Jul 30, 2013 8:54 am
First name: Trevor
Last Name: Gore
City: Sydney
Well, opinions differ on that. I would suggest you read his website rather than his book. You'll stand a better chance of getting it right.
http://www.cumpiano.com/Home/Book/textbook.html
Techniques have moved on quite a lot since Cumpiano and Natelson wrote their book. If you want to start by adjusting necks, most of the ones you'll see will be dovetail joints or bolt-ons. Cumpiano covers neither of those in his book. You'd be better off looking for a repair book (try the ones by Dan Erlewine or Don Teeter; just Google their names).
http://www.goreguitars.com.au
PostPosted: Mon Aug 05, 2013 7:09 am
First name: Ganasen
Last Name: Govender
City: Germiston
State: Gauteng
:) :) :) :) :) :) :) :) :) :) :) Thanks for the information
