It is currently Sat Sep 20, 2025 7:11 pm
 Post subject: Sepele Neck Wood
PostPosted: Wed Oct 09, 2013 9:26 pm
First name: EddieLee
Last Name: Brown
What is your opinion of using Sepele for an acoustic guitar neck.
I bought some thinking it would have a nice look but be comparable to Mahogany. The piece I received is much denser than the Mahogany I have been using. I am worried that it may be a bit to heavy.
_____________
EddieLee
 Post subject: Re: Sepele Neck Wood
PostPosted: Wed Oct 09, 2013 10:00 pm
I think it' great for electrics.
I try to build my acoustics a s light in weight as possible.
However for steel strings I don't use Spanish Cedar, and instead try to find light weight Honduras Mahogany.
Sapele is just too heavy for me.
However, LOTS of builders use Mapl for necks with good results, so I don't see why you COULDN'T use a heavier wood like Sapele.
Old growth, shmold growth!
PostPosted: Wed Oct 09, 2013 10:10 pm
Sapele makes wonderful necks, even on acoustics. While the weight difference is noticable when handling the large blank, once you whittle awake all the wood that isn't a neck, the weight difference will be minimal.
Very stiff, stable, carves and finishes nicely.
PostPosted: Thu Oct 10, 2013 5:37 am
It's nice and certainly a lot nicer than the khaya I got, which has a rougher texture. Sapele is harder to carve than Honduran mahogany and perhaps the grain isn't quite as open. In fact I don't bother filling the grain. Mostly you will come across the stuff with the prominent stripes but I've had a piece that was more of a dark chocolate type colour, which I found more appealing. Wish I could get more of that type.
PostPosted: Thu Oct 10, 2013 5:48 am
City: Tyler
What Grumpy said. I have not found it to be noticably harder to carve. It is all I use now.
PostPosted: Thu Oct 10, 2013 9:01 am
Last Name: Brown
Thanks for the input.
Michael, I have friends that got some scrap wood from a saw mill. They were told it was Mahogany. It was really Sepele but a few piece were Coffee Latte brown when they put finish on it. It was very attractive. I was confused by that but it fits with your comment.
_____________
EddieLee
PostPosted: Thu Oct 10, 2013 9:17 am
This is it with a water clear finish:
PostPosted: Thu Oct 10, 2013 10:06 am
First name: Danny
Last Name: Vincent
I have a L-00 with a Sepele neck. I's great. Even on a small guitar the little extra weight is not overly noticeable. I have more neck stock and will use it again.
PostPosted: Thu Oct 10, 2013 11:57 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I used it on an OM. The extra weight is noticible, but not so much so
that I would contemplate replacing it with HOG. I'm using it on the
12 fret OOO I'm building now. It should be even less noticible on the
shorter neck.
Gene
PostPosted: Thu Oct 10, 2013 4:34 pm
First name: Ringo
I would add that it really smells nice too.
PostPosted: Thu Oct 10, 2013 8:53 pm
Last Name: Brown
I will give it a go. Thanks.
_____________
EddieLee
PostPosted: Fri Oct 11, 2013 6:43 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Another thumbs-up here - I recently built 6 electrics with Sapele necks (and backs) and agree with Grumpy's sentiments - "stiff, stable, carves and finishes nicely"
With dark pore-fill the grain pops nicely.
These users thanked the author Robbie_McD for the post: DannyV (Fri Oct 11, 2013 7:44 am)
