It is currently Mon Aug 18, 2025 12:17 am
PostPosted: Fri Oct 18, 2013 4:37 am
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Have a look at this, unless you want something
other than constant radius.
http://www.freudtools.com/p-180-round-nose-bits.aspx
Ken
PostPosted: Fri Oct 18, 2013 7:36 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I bought this set a few years ago. http://www.amazon.com/Woodline-WL-2094- ... er+bit+set
Alex
PostPosted: Fri Oct 18, 2013 8:17 am
Hi Filippo,
Are you looking for something like the large ovolo bits Amana offers?
If you want a shallower cove profile you can use a core box or round nose bit of a larger diameter and not use the full profile.
PostPosted: Fri Oct 18, 2013 8:27 am
State: Tennessee
Filippo Morelli wrote:
Guys, I need what is starting to look like a special router bit for a design I'm working on. I need a cove bit profile, but WITHOUT the bearing. I don't need a box bit nor a bowl bit. Specifically the more gentle curve of a cove bit.
Anyone have pointers or suggestions where to look? I've already done a variety of basic searches ...
Filippo
Whiteside will make you anything you want in the good ol USA to boot, and won't skin you in the process. My dad and brothers have cabinet/furniture shops and have had several bits made with great results.
PostPosted: Fri Oct 18, 2013 10:38 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Give these guys a shout. They should be able to fix you up.
http://www.misenheimerinc.com/products.html
PostPosted: Fri Oct 18, 2013 3:15 pm
It might help to know the dimensions of the rout you want the bit to make and what use you are putting it to. If we understand the problem we might be better able to suggest solutions.
I make large shallow coves using a table saw and different diameter saw blades. That is how I generally shape the heel on the guitar necks. Radius dishes are large flattened coves in cross section made with various methods. More than one way to skin a cat.
PostPosted: Sat Oct 19, 2013 9:23 am
I think if you search for "Corner Radius End Mill" you'll find what you're looking for.
