It is currently Thu May 14, 2026 3:35 pm
PostPosted: Fri Mar 21, 2014 5:13 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
One thing I discovered making bridges out of african blackwood is that it's significantly harder to sand than ebony. It just seems like the wood is harder overall and exudes some kind of sap that clogs sandpaper quickly. Is it normal to change sanding drums, belts, etc. more often when working with african blackwood?
I tried using a file to shape it and the file struggles to even take off a little bit of material...
Typhoon Guitars
PostPosted: Fri Mar 21, 2014 5:50 am
African blackwood is rather fiberous, try inlaying into it sometime. Routing it is a pain. You may have some very green AFB also as the stuff I have sands pretty well. Don't have much trouble filing and sanding it, but as with any oily wood, if I run it through the drum sander, it can load the belt pretty fast. Certainly wouldn't go much finer than 80 grit on the drum...
It is usually a lot heavier and harder than ebony and if you drop a piece on a steel table, it pings rather more than ebony.
PostPosted: Fri Mar 21, 2014 5:56 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't know, it doesn't feel green at all. Feels kinda dry in fact but it exudes oil when heated (which is invariably caused by sanding)
Typhoon Guitars
PostPosted: Fri Mar 21, 2014 5:57 am
Like I said, it's an oily wood. More like BRW or Cocobolo than ebony.
PostPosted: Fri Mar 21, 2014 6:02 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So the question is, how do I glue it? Will hide glue work or do I need to use epoxy?
Typhoon Guitars
PostPosted: Fri Mar 21, 2014 6:05 am
I don't have a problem with HHG.
PostPosted: Fri Mar 21, 2014 6:07 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So just glue it straight up like any other wood? Or do I treat the surface with acetone or something?
Typhoon Guitars
PostPosted: Fri Mar 21, 2014 7:36 am
I've used African blackwood for acoustic guitar bridges for years, I just glue them on with hot hide glue, with normal surface preparation prior to gluing (preferably scraped). My steel string guitar bridges are usually only about 1", for guitars normally strung with medium strings, and as far as I know, none have lifted yet, so the procedure seems to work fine. Its also a fine wood for fingerboards, of course. I don't think of it as particularly oily for a rosewood though, perhaps you found an unusual piece? I buy the wood as smallish sticks, from a local shop that sells turning blanks, so I assume they are from several different trees. I haven't noticed much difference between them, it seems like a fairly uniform wood.
PostPosted: Fri Mar 21, 2014 7:44 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I get them from a local lumberyard who just saws them into slabs out of logs. The particular one was part of an offcut and was full of cracks and defects. The reason I used it is because I made a bridge for a guitar I am building out of ebony but messed up on the saddle slot (it's a lot wider than they need to be, and with really rough edges and not particularly straight either). So I decided to just start over and try the african blackwood and see how it sounds compared to ebony...
Typhoon Guitars
PostPosted: Fri Mar 21, 2014 8:19 am
I ABW almost exclusively for bridges, bindings and headplates .. for bindings I am using CA, but for bridges and headplates, titebond is fine ...
PostPosted: Fri Mar 21, 2014 12:22 pm
First name: Ringo
Yep, ABW will clog sandpaper in a hurry and especially in a thickness sander. It should glue up just fine with a freshly scraped or sanded surface with pretty much any glue; no need for acetone or solvents... in fact using solvents can cause problems. Treat it like any other rosewood and you should be just fine.
PostPosted: Fri Mar 21, 2014 6:36 pm
Last Name: Beaver
City: Lake Forest
African blackwood is actually a rosewood. It has the oiliness and is difficult to power sand pretty much like most rosewoods. It is also finishes beautifully and takes a great shine but it is the heaviest and one of the toughest woods out there.
Joe Beaver
Maker of Sawdust
Users browsing this forum: No registered users and 84 guests
