It is currently Fri Aug 22, 2025 3:08 am
 Post subject: which saw blade
PostPosted: Tue Nov 12, 2013 6:23 pm
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
There it is, which saw blade should I get for my table saw?
 Post subject: Re: which saw blade
PostPosted: Tue Nov 12, 2013 6:41 pm
First name: Tom
Last Name: Rein
City: Saline
This is a phenomenal blade:
http://www.amazon.com/Tenryu-GM-25540-Carbide-Tipped-Blade/dp/B000FXY38M/ref=sr_1_1?s=hi&ie=UTF8&qid=1384299412&sr=1-1&keywords=tenryu+gold+medal
You can spend less but the $50 more you spend for the Tenryu over a $50 generic blade is the best $50 you'll spend this year.
Stay with the happy people.
--Reynolds Large
PostPosted: Tue Nov 12, 2013 7:06 pm
First name: Alan
Last Name: Tobler
City: Tucson
State: Arizona
Zip/Postal Code: 85748
I cut a variety of materials (plywood veneer, hardwoods, melamine, etc..) so I use a couple different blades. A 24 tooth for ripping, a 80 tooth for melamine, and a 60 tooth for plywood veneers and crosscutting. As Todd mentioned above the Freud Diablo is a good blade and not that expensive. I just picked up a new 10" Freud Diablo rip blade today for $27.00 at HD. I prefer carbide tipped whatever blade I use. If you had to get just one blade the 60 tooth combination would work.
The dullest pencil is sharper than the keenest mind.
PostPosted: Tue Nov 12, 2013 8:11 pm
First name: Tom
Last Name: West
State: Nova Scotia
Freud Diablo is the blade I use for most of my guitar table saw work. The table saw is the power tool I use the most. Thin kerf as Todd pointed out makes less sawdust, cuts much easier then wider blades, leaves a very nice cut. Think I paid less then $10.00. Bought 2 about 4 years ago and the second one is still on the nail ,unused. Our friend Grumpy.......AKA Mario put me on to them, and I sure appreciate that.......Thanks Mario.
Tom
PostPosted: Tue Nov 12, 2013 8:16 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
So you guys are using 7-1/4" blades? What is the saw's blade capacity?
Ed Minch
PostPosted: Tue Nov 12, 2013 8:19 pm
Last Name: Shaw
City: Philadelphia
State: PA
Zip/Postal Code: 19125
I use the Freud 10" 60 tooth combination blade.
Another day, another dollar.
PostPosted: Wed Nov 13, 2013 6:03 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
One reason for using a 7 1/4" blade on a 10" table saw is the thinner kerf of the smaller blade.
PostPosted: Wed Nov 13, 2013 8:25 am
Ed Minch
1 5/8" on my Dewalt jobsite saw,1 7/8" on my old 8" Crafstman.
PostPosted: Wed Nov 13, 2013 9:05 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I used to spend the money on Forrest and other premium blades, but in the last 5 years the cheap
carbide blades like the Freud Diablo have gotten extremely good. The 7 1/4" has the advantage of
a thinner cut, but the 10" blade cut just as smooth. I don't see the need to spend the money for
the premium blades any more.
Gene
PostPosted: Thu Nov 14, 2013 7:55 am
Last Name: Minch
City: Chestertown
Todd
Thanks for that - I have been using a 10" Craftsman thin kerf, all purpose blade since January of '09 when I cut miles of 2X yellow pine for a workbench top. It is still on the saw, and granted I don't use the table saw much, but it still does a good job. I will try one of the smaller blades for exotic woods.
Ed Minch
PostPosted: Thu Nov 14, 2013 9:47 am
I have a fair number of special purpose table saw blades, but the two used the most are the 10 inch Freud thin kerf combination blade and the 7 1/4 inch diablo.
One advantage not mentioned about the thin kerf blades (although Tom alluded to it) is that they require less power to make the cut, which is a plus for the average under powered homeowner table saw. The Freud has the further advantage of the special coating on the plate to reduce friction.
The 24 tooth 7 1/4 inch diablos work fine for most cuts and I have caught them on sale at HD , 2 for $10 (I don't know if we will see those prices again!).
PostPosted: Thu Nov 14, 2013 10:13 am
First name: Ron
Last Name: Belanger
+1 for the 7 1/4 Diablo.
PostPosted: Thu Nov 14, 2013 11:45 am
First name: Stuart
Last Name: Gort
+1 for Diablo.
StuMusic
PostPosted: Thu Nov 14, 2013 12:00 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I have Freud, Simonds, Micor, CMT, and some house brand blades. They all cut really well as long as they are kept clean. As soon as resin glaze builds on the teeth, the best blades won't cut very well.
Alex
