It is currently Thu Aug 21, 2025 3:39 am
 Post subject: Z-Poxy Shelf Life
PostPosted: Fri Nov 15, 2013 10:35 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Quick question wrt Z-poxy. Does anyone know the shelf life of both unopened and opened Z-poxy? I am using this for pore fill, not structural bonding. I have a lot of Z-poxy leftover form my first 2 guitars, been opened about 1 year, but stored in my workshop and sealed tight. I also have a box of unopened that I bought recently, so I can throw out the older one, and use the new. However, I would prefer not to wage it if it is still good.
Thanks!
Glenn
 Post subject: Re: Z-Poxy Shelf Life
PostPosted: Fri Nov 15, 2013 11:57 am
First name: Stuart
Last Name: Gort
Mix up equal parts without using any kind of thinner...and drop a dollop on a piece of cardboard.
If the next day, after having it in your house (assuming 65+ degrees) overnight, the surface is smooth to the touch and you can't dent it with your fingernail...it's fine.
Most epoxy components have a very long shelf life...but the time is irrelevant if the test above produces the described result.
StuMusic
PostPosted: Fri Nov 15, 2013 3:32 pm
Last Name: Beaver
City: Lake Forest
I agree with Stuart. The hardener will darker over time but that doesn't effect the final outcome.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Nov 15, 2013 4:24 pm
First name: Glenn
Last Name: LaSalle
Thanks guys! I will try that.
Glenn
