It is currently Thu Aug 21, 2025 4:18 pm
PostPosted: Fri Nov 22, 2013 12:36 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I have been using laminate trimmer for inlays or rosettes, it's kinda a little heavy for the job and doesn't offer the best visibility. I have a foredom type tool (it is not a foredom, but something like it) but no router base for it.
Has anyone built a router base for their own rotary tool out of plexiglas?
Typhoon Guitars
PostPosted: Fri Nov 22, 2013 2:57 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Not sure if this will fit your tool or not, But you can contact John and ask, He will know.
http://www.bluescreekguitars.com/shop/i ... cts_id=181
Brian
PostPosted: Sat Nov 23, 2013 11:12 am
You can mount the Foredom hand piece that Stewmac sells which is threaded to use in their Dremel base.
PostPosted: Sat Nov 23, 2013 11:19 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
The Stewmac customized handpiece costs 70+ dollars... which is a little steep considering it's just a handpiece. Not even sure it will work with my foredom type unit... I know foredom is quality and all, but still...
I think I'll try making them myself.
Typhoon Guitars
PostPosted: Sun Nov 24, 2013 7:10 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
Bishop Cochran makes a base for the Foredom tool
http://www.bishopcochran.com/foredom.htm
Listed at $169, which isn't too bad for a small volume percision toolbase. I don't know if
shipping would be a big deal for you, however.
Gene
