It is currently Sun Aug 03, 2025 8:28 pm
 Post subject: Vacuum Clamps
PostPosted: Wed Mar 05, 2014 3:26 pm
First name: Peter
Last Name: Norman
City: Grand Falls-Windsor
State: NL
Zip/Postal Code: A2A2V6
Been thinking about buying a vacuum clamp system. The one I've been looking at is from Lee Valley. http://www.leevalley.com/en/Wood/page.a ... at=1,43838
Just looking for some advice on what to buy, and if there's even really a need for such a system, and what everyone uses theirs for.
 Post subject: Re: Vacuum Clamps
PostPosted: Wed Mar 05, 2014 5:47 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Reading their blurb always sounds nice & then the pic shows you some example that can easily be done in a vice. I think you have to really imagine how you would use them before you buy.
I do a fair bit of vac bag veneering and have from time to time needed some kind of a vac clamp but that is not the one I could use. I have the vac bridge clamp & like it.
MM
Mike McNerney
PostPosted: Wed Mar 05, 2014 6:14 pm
First name: Peter
Last Name: Norman
State: NL
Another clamp system that I was looking at was on http://www.clampusystems.com/SS-Venturi.html
The problem is that I don't think they'll ship to Canada, and if they do, by the time I get it shipped it will probably be well over $100.
I was hoping to use the vac clamps to hold the guitar while scraping, routing binding, etc. After watching Robbie O'Briens tip du jour, it seems a vacuum clamp would take a lot of aggravation out of working alone and always rigging clamps to hold my guitar.
Has anyone used such a clamp for these jobs? Will the vacuum keep suction on wood with the pores?
PostPosted: Wed Mar 05, 2014 6:42 pm
Last Name: Garrish
Pores- yes, holes- no.
It's much cheaper to get vacuum gasket from somewhere like Allstar Adhesives, or McMaster Carr, and make your own clamps. They're just a piece of wood/mdf/acrylic/ABS/whatever's in the shop with a hole in it and a slot for the gasket. You don't even need fittings, you can drill a vacuum hole a bit bigger than your hose and just use an o-ring around the hose to make a seal (good tip from Stuart Gort, there).
I like the Venturis from Vaccon, I think they're the best. They ship to Canada, or have a distributor here. I don't remember how the pricing was, but I thought I was really low when I bought my Venturis from them.
Bob Garrish
PostPosted: Thu Mar 06, 2014 6:31 am
First name: Rusty
My Acme Leaks-A-Lot Vac rig requires a lot of clamps around the frame and a continually running pump but It gets the job done with plenty of squeeze out.
Btw, first time I fired it up to see what it would do, I wrecked the bathroom scale.
PostPosted: Thu Mar 06, 2014 7:12 am
Last Name: Farmer
City: Durango
State: CO
I tried searching but can't find Stuart Gort's hose connection tip.
I like the price point.
Can you elaborate Bob?
PostPosted: Thu Mar 06, 2014 5:04 pm
Last Name: Garrish
If you put an o-ring on your hose and push it into a hole, it'll make a good enough seal to hold your vacuum. Because it's vacuum, the hose will pull itself into the hole and hold itself there alright.
All you need is a hose, an o-ring that fits on it, and a drill just a bit smaller than the outer diameter of the O-ring.
I'm a big fan of push-fit connectors, and they're really cheap at Princess Auto (~$1 apiece), but I do hate having to tap NPT threads for them. Inside those, though, it's just an O-ring and a ring of 'teeth' that hold the hose in.
Bob Garrish
