It is currently Tue Aug 05, 2025 2:10 am
 Post subject: Fretboard radius
PostPosted: Thu Mar 06, 2014 1:16 pm
First name: Jon
Last Name: Shurtleff
City: Huizen
Zip/Postal Code: 1273aw
Country: Nederland
I see that guitars have a wide range of neck radiuses from 7.25 to 16 or so but I'm having a hard time finding information on the pros and cons of different radiuses, except that a cone shape neck is a better idea than a cylindrical neck.
Any comments?
Jon.
 Post subject: Re: Fretboard radius
PostPosted: Thu Mar 06, 2014 3:18 pm
The tighter radii are in less use these days I think. The tighter it is for some people it's easier and more comfortable to barr chords but also when bending strings as you go up the radius on the tighter ones you will fret the note out on the next fret.
It's mostly personal preference but that's a couple reasons why it's done with any potential problems anyway.
PostPosted: Thu Mar 06, 2014 9:53 pm
Last Name: Beaver
City: Lake Forest
I usually use a 16"radius tapered into 20" on steel string.
Keep in mind that on a wider fingerboard a given radius will seem more pronounced, hence my reason to taper to 20" on the wider portions of the board.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Mar 07, 2014 12:54 am
The really tight radii have unique geometry problems, especially with extremely long tapered profiles like on a Jazz bass, besides the note bending problem.
Old growth, shmold growth!
PostPosted: Fri Mar 07, 2014 8:58 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
In the end it comes down to player preference, mine is for a 10" R board. Most of waht I make these days is a compound radius of 12"- 16" and most seem to find it agreeable. Another thing that has to play into this equation is the neck thickness and carve shape. All these contours must flow together and work with each other to create a comfortable playing guitar.
Brian
Users browsing this forum: DennisK and 39 guests
