It is currently Thu Aug 14, 2025 3:34 am
PostPosted: Thu May 08, 2014 1:06 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I don't know what is it about ukeleles, but no uke build I do ever goes well. Guitar often goes fine albeit with some minor problems, but for whatever reason every single uke I try to build has a problem one way or another. Well today I have a major problem. I was gluing the neck in, but for whatever reason there's that gap on ONE SIDE that refuses to go away so I thought I apply more clamping pressure on the heel to close it. Well next thing you know I hear a loud crack and the tail block has separated from the back!!!
Last uke had the wrong neck length, and the one before that sounded terrible. What is it with ukes?? It's hard to build and on top of that, nobody wants to pay more than $100 for one because everyone sells it so cheap. Even an all koa Kamaka sells for $800 and given how much work it takes to make one, I wouldn't build it for $800.
Typhoon Guitars
PostPosted: Thu May 08, 2014 7:31 am
You wanna talk frustration?
Let's talk banjos.
PostPosted: Thu May 08, 2014 7:38 am
Where were you clamped?
Neck heel to tail block?
PostPosted: Thu May 08, 2014 7:57 am
With all do respect, applying more pressure in an attempt to get rid of a gap in a poor fit is rarely a good idea. The approach should be to correct the fit.
PostPosted: Thu May 08, 2014 8:33 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I clamp heel to tail in order to make sure the neck seats correctly, because sometimes the heel does not always sit flush with the body, as it seems the force of actually clamping the neck to the body wants to push the neck the other way... it makes for a seamless joint and normally very small amount of force is required... but for whatever reason there's always that gap on one side of the heel that will close when I dry fit them, but remains open when glue is applied.
Typhoon Guitars
PostPosted: Thu May 08, 2014 8:43 am
Hi Tai,
Ukuleles are supposed to be a fun build. If you are not having fun then you are doing something wrong. The shapes and sizes can be just about anything.
The last Uke I built used a neck from a homemade mandolin banjo someone gave me. Part of the fun was figuring out what to do with the extra holes in the peghead. It was a soprano scale mounted on a concert sized body -I joined it at the 10th fret. I used some small pieces of rosewood for the back and sides. Is it a world class Ukulele like Bob Gleason builds? Definitely not. But it plays reasonably in tune and someone will have fun with it.
PostPosted: Thu May 08, 2014 8:57 am
Tai, I'm not trying to give you a hard time, but everything happens for a reason and the words you are using suggest that you don't understand why you are getting the gaps. I would encourage you to spend the time to figure this out and learn how to correct them. If you do, that will make your next builds easier and better.
PostPosted: Thu May 08, 2014 9:09 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So where do I start with this? One hard thing is gaps seems to appear out of nowhere, with absolutely no indication as to why they are there. Is there a good primer I can read on dovetail heel fitting? So I am guessing using a clamp on the heel to the tail block is not the right way?
Typhoon Guitars
PostPosted: Thu May 08, 2014 10:03 am
I'm no expert on dovetail neck joints - for ukuleles I use a single hanger bolt which seems more than enough to me. John Hall has an excellent series of videos on setting dovetail neck joint on a guitar starting here: https://www.youtube.com/watch?v=L3YJh9OT4mw
PostPosted: Thu May 08, 2014 10:19 am
Clay S. wrote:
Hi Tai,
What did you do with the extra tuner holes in the end? Was that the one you were thinking of giving options at the bridge for 4 and 6 strings?
PostPosted: Thu May 08, 2014 10:23 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
That statement makes me suspect hydraulic pressure from excess glue that can't squeeze out. Personally, I don't build ukes and don't use dovetail neck joints on guitars, but I've certainly had experience with trapping glue in other woodworking joints that won't close.
These users thanked the author Tim Mullin for the post: Rod True (Thu May 08, 2014 2:08 pm)
PostPosted: Thu May 08, 2014 11:46 am
Hi Nick,
The one I wanted extra holes in the bridge for stringing options is a baritone guitar not the uke.
If you look at the design of the top of the peghead and the place where the ribbon ties for hanging it up you can see how I "fixed" the extra holes. I thought about plugging and refacing the front and back of the peghead, but decided that was more work than I wanted to do for this little uke. It was a fun project and I kept it that way.
And to keep things simple the rosette channel was made at the same time as the soundhole, using the holesaw within a holesaw method.
Hi Tai,
some uke builders use a glued on butt joint for their ukes. It works.
PostPosted: Thu May 08, 2014 11:52 am
Cool, it looks like a fun project!
Nice nod to the neck's former life as a mandolin banjo, too!
And, Tai, I used a bolt on butt joint as per Mottola's instructions on a baritone uke sized guitar. Worked very well.
PostPosted: Thu May 08, 2014 12:09 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I tried bolt on before, and the problem is the body is so small that it was hard to actually get a bolt in there... or get a tool in there to manipulate the bolt. I thought I do a dovetail because of the challenge and I thought it was a secure joint. I heard of a glued on butt joint but I didn't think it was strong enough.
Typhoon Guitars
PostPosted: Thu May 08, 2014 1:00 pm
If you have big hands like I do, for a bolt on neck fit an end pin and use that hole to access the bolt with a fabricated extension/allen key.
PostPosted: Thu May 08, 2014 1:38 pm
First name: Rusty
Colin,
That's a great idea. I think I'll do that with my next tenor. I've been worrying a little about how I am going to screw in a neck bolt, not easy with my hammy hands. Plan B was to go dovetail.
PostPosted: Thu May 08, 2014 1:42 pm
It can't be plan C for Colin - Not my idea.
Stole it from someone else on the forum, Dave Stewart I think?
