It is currently Sat Aug 02, 2025 4:50 pm
PostPosted: Tue Apr 08, 2014 9:27 am
First name: Chuck
Last Name: Hutchison
City: Houston
Guys, I just can't get my brain wrapped around how I need to build a stand for my buffer set up. I have searched on the OLF and Google images for some ideas but can's seem to see what I need to do, I want to make it with plywood and 2 X 4's. I thought about having the motor hang from the belt on a slide using gravity to keep the belt tight, or making a small flat top table and mounting the motor on a plywood slide pushing the motor tight and bolting down with carriage bolts and nuts. Btw, the pulley on the motor is 2.5"
Anyone have any detail photo's of the stands you have built with wood. Here's a couple photos of the buffer and motor I have.
Thanks for you help,
Chuck Hutchison
PostPosted: Tue Apr 08, 2014 10:21 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I would look at the stewmac plans for there buffer including the base: http://www.stewmac.com/shop/Finishing_supplies/Buffing/StewMac_Guitar_Buffer_Complete_Outfit.html#shop/Finishing_supplies/Buffing/StewMac_Guitar_Buffer_Complete_Outfit.html?tab=Instructions&_suid=1396970380606008566682803581477
On that page they have an instructions tab that shows the base you need to make for their buffer.
PostPosted: Tue Apr 08, 2014 11:44 am
Last Name: G
I remembered seeing this one :
viewtopic.php?f=10101&t=31820#p420193
Don't know if that's any help or not.... cheers
PostPosted: Tue Apr 08, 2014 12:24 pm
FWIW, I bought a grinder stand from Samona that was 69$. Super heavy, doesn't vibrate.
PostPosted: Tue Apr 08, 2014 2:22 pm
Call me
I have to take pics of my set up but I placed the main buffer on a narrow board so it hung over the edge the motor is set on a hinged board so the weight of the motor is the belt tension.
PostPosted: Tue Apr 08, 2014 2:41 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
chuck h, harbor freight is ur friend .Don/t have photo , but their grinder stand is way cheap.Call em./,
PostPosted: Tue Apr 08, 2014 10:31 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
This is essentially what I did, which I think is similar to what John & others have done too.
Kevin Looker
I'm not a luthier.
PostPosted: Wed Apr 09, 2014 5:47 am
Here are the pics of my buffing set up. Note the buffer is extended over the base for more access to the buffing wheels.
PostPosted: Wed Apr 09, 2014 7:49 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Mine is very simply constructed and permanently attached to the wall. I have a light on flexible pole above it that I can position to see across the surface as I work. I have seen John's with the hinge and prefer a rigid arrangement. That same arrangement is used on many 10" saws and if you watch one cut into heavy stock from the side you will see the motor begin to hop around a bit. That sets up vibration in the system and causes slight variances in rpm. IMO that's part of the reason a good cabinet saw cuts smoother and why most industrial buffers these days are direct drive.
Brian
PostPosted: Wed Apr 09, 2014 7:05 pm
mine does not vibrate and it is smooth also I only use a 1/4 hp motor .
PostPosted: Wed Apr 09, 2014 8:53 pm
First name: Chuck
City: Houston
Thanks for all the replies guys. They were all very helpful to get a vision of what I needed to do. I made a platform like stew-Mac but hinged the motor like John Hall. Thanks John.
Sent from my walkie talkie using Tapatalk
PostPosted: Wed Apr 09, 2014 9:47 pm
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
ImageImageImage i'm still working on mine!!
May your sails be full & your glass never be empty!
PostPosted: Thu Apr 10, 2014 8:48 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
David , I/d like to build a similiar set up. I have motor. pulleys ,plywood, hinges, but no rod , bearings , or buffs .Could you please explain your set up and where you got the parts ??? buffs , pillow bearings, rod etc . thanks.
PostPosted: Thu Apr 10, 2014 9:05 am
Last Name: Lee
Country: Wales U.K.
All of these on eBay.
PostPosted: Thu Apr 10, 2014 11:42 am
First name: David
Last Name: Eddy
City: Mandeville
State: La
Ernie,
I was lucky enough to find all the parts in my grandfathers old workshop! He was a collector of all crazy parts and pieces!!! The only challenge I had was to find a friend that could cut left-hand threads on a 1 inch shaft. I found the buffs on line but can't remember exactly where? Sorry I'm not much help. I do like the design of folding down the buffer and being out-of-the-way!! Image This is a close-up picture of all the parts of the main foundation of the buffer very simple aluminum pipe and flat bar. I found the pillow blocks on eBay for super cheap and the bolts go all away through down to the bottom of the plywood
PostPosted: Thu Apr 10, 2014 8:53 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Thanks for the explanation an photos david .I/ve got spare parts too . Guess it/s time to build one. I have the beall 8in buffs on a 1/2hp motor/But it/s for buffing small instruments and parts.
Users browsing this forum: ChuckB, DanSavage and 52 guests
