It is currently Tue Aug 12, 2025 8:28 am
 Post subject: Buffing motor
PostPosted: Mon May 12, 2014 3:39 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
What size motor do y'all use on buffers? I ask cuz I just bought a new condenser motor for an AC unit that is irreparable. So now I have a brand new motor that I can't take back. Trying to find a use for it.
 Post subject: Re: Buffing motor
PostPosted: Mon May 12, 2014 3:58 pm
Half a horse here, run a slack belt.
PostPosted: Mon May 12, 2014 4:14 pm
Same here...doesn't take a ton of force to stop the wheel. Allow plenty of adjustment so you can play with it.
PostPosted: Mon May 12, 2014 4:25 pm
Forgot to mention, aimed for the same speed (FPM) as the new SW buffer, with 12" wheels.
PostPosted: Mon May 12, 2014 10:23 pm
1/3
PostPosted: Mon May 12, 2014 11:01 pm
PostPosted: Tue May 13, 2014 7:27 am
First name: Zeke
Last Name: McKee
Looks like this motor will turn out useful after all! Now to do some math to figure out the SFPM. Thanks guys!
PostPosted: Tue May 13, 2014 7:41 am
Last Name: O'Melia
City: Huntsville
State: Alabama
No more than 1/2 hp, 1/3 preferred, rpms under 1000, 800 is target. U should be able to stall the wheel with some force. Grizzly supplies the shop fox arbor for around $100. Well worth it. Caswell Plating supplies very nice wheels. I use two 14" wheels on each side.
PostPosted: Tue May 13, 2014 7:55 am
Even a 1/4 HP will work ... not a lot of torque req'd. 14" buffs develop quite a bit of flywheel type momentum.
Milton, ON
PostPosted: Tue May 13, 2014 3:32 pm
Speed will depend on what type of finish you're buffing. I run 12" buffs at 1:1 (1740 rpm) for polyester....
Users browsing this forum: roby and 40 guests
