It is currently Mon Sep 15, 2025 8:02 am
PostPosted: Thu Jun 19, 2014 2:23 pm
I have a fixer upper on my bench, an old Yamaha. The geometry is decent, but the action is way high due to way way way too much relief, and the truss rod is as tight as it can get. Is there a fix for this?
Rod adjusts at soundhole...
PostPosted: Thu Jun 19, 2014 3:44 pm
partial compression fret job
PostPosted: Thu Jun 19, 2014 3:51 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
FIRST - determine if the rod is, in fact, as tight as you think it is. Take the adjusting nut all the way off, use some nice white grease (or heavy oil, or pretty much any lube you have at hand) then replace it and try adjusting again. This simple trick has saved countless hours of anguish around these parts. . .
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Thu Jun 19, 2014 4:21 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Installing a washer or two (or three or four) on the end of the truss rod and then retightening the nut wouldn't work because ...????
PostPosted: Thu Jun 19, 2014 4:32 pm
duh Maybe depends on the truss rod - 1 way/2 way?
PostPosted: Thu Jun 19, 2014 9:46 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Turn it the other way and see if it tightens as well. It could be a 2 way truss rod that was tightened the wrong way.
Typhoon Guitars
PostPosted: Thu Jun 19, 2014 9:55 pm
Definitely old school. 20 yr old Yamaha. Even greased it just hits a stop point. Cest la vie...
PostPosted: Fri Jun 20, 2014 1:10 am
First name: Frank
Last Name: Ford
City: Palo Alto
Adding washers might help if the nut is at the end of the threads, and they wouldn't do any harm, so they are often useful.
The reason for lubrication is to rule out seizing of the threads which is very common with older truss rods that were often installed without any at all. The simple act of removing and replacing the nut can do wonders. Grease or oil will make things work nicely, and the washers might be just the thing to add to the process. Coming to the end of the threads is much less common, but always a possibility.
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Fri Jun 20, 2014 2:13 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
How much is "way way way too much"? .030--.040" might be taken out by a refret, and fingerboard planing. Above that, you might also need a heat-set, or compression refret, or both. Everything can be fixed.
I think Tai has linked to a dynamite relief solution. I'm looking forward to trying it.
PostPosted: Fri Jun 20, 2014 9:42 am
Well, this was a donation guitar for a fundraiser. I said I'd do what I could for nothing, but a refret/ fingerboard plane and such go beyond what I'll do for free. I'm nice, but not that nice...:)
Thanks for the help though!
PostPosted: Fri Jun 20, 2014 9:45 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
If the rod is either frozen or whatever and nothing will fix it, then it's a pretty major problem. I don't think anyone will do that for free.
Typhoon Guitars
PostPosted: Fri Jun 20, 2014 11:55 am
First name: Frank
Last Name: Ford
City: Palo Alto
I agree - We do lots of free work on guitars donated to the Hero's Voices program of the VA, and you're absolutely right - sometimes it's not appropriate to rebuild and restore.
There's a gigantic supply of old tired instruments that can't "support" major work. It's great to recycle the ones that can be reworked with minimal effort, and absolutely reasonable, right and proper to discard many of those that have died along the way. We're not talking about products of the dedicated luthier, but commodities that are produced in far greater numbers than most are aware of.
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
PostPosted: Fri Jun 20, 2014 12:03 pm
I did that once many years ago. The neck was prety bowed, and by the time I got the neck straight, the fretboard developed a crack at the end above the rod. It was a Strat neck.
I don't do that anymore. If indeed the rod is TRULY maxed ot, I wouldn't do that again, because the neck could be bowed beyond the range of the truss rods ability to function as designed.
Old growth, shmold growth!
Users browsing this forum: A.Hix and 42 guests
