It is currently Sun Sep 14, 2025 5:29 pm
PostPosted: Sun Jul 13, 2014 11:10 am
First name: Wendy
Last Name: W
State: Arizona
Does it work for classical nuts or just steel string?
PostPosted: Sun Jul 13, 2014 11:30 am
That's a good question. I would think only for SS. The ruler is slotted to bring each pair a little closer as you move across the board to account for string thickness. Since classical strings are all the same thickness I would imagine it would be better to make them equidistant...
PostPosted: Sun Jul 13, 2014 12:23 pm
classical strings arent all the same thickness BTW .. I use the spacing rule for classicals and its fine ....
PostPosted: Sun Jul 13, 2014 12:27 pm
Classical strings tend to have similar treble and bass thicknesses, i.e 2 sets 3 of similar sizes e.g. EJ45 Pro-Arte Nylon -
Trebles .0280, .0322, .0403 Basses .029, .35, .043
SM spacing rule, don't know but.......
Most builders seem to use equal spacing according to the Delamp CG site.
PostPosted: Sun Jul 13, 2014 12:57 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I use it on my classicals, the increased spacing is pretty subtle; probably less than the error in measurement I would make without it. It allows you to space the strings for exactly the E - E distance you want, and because you mark through the slots, it is very consistent and accurate,
PostPosted: Sun Jul 13, 2014 1:57 pm
I use it on classicals too. Works just fine.
PostPosted: Sun Jul 13, 2014 2:35 pm
First name: Wendy
Last Name: W
State: Arizona
Thanks, seems the consensus is that it works so I will give it a try.
Wendy
PostPosted: Sun Jul 13, 2014 4:11 pm
First name: Lonnie
Last Name: Barber
City: Manchester
State: Tennessee
Zip/Postal Code: 37355
Well worth the investment.
PostPosted: Sun Jul 13, 2014 5:13 pm
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
It's way easy and cheap to make your own - and you can have the benefit of any number of variants, to suit all kinds of needs and instruments:
http://www.frets.com/FretsPages/Luthier ... trule.html
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post (total 3): Imbler (Sun Jul 13, 2014 9:14 pm) • Lonnie J Barber (Sun Jul 13, 2014 7:26 pm) • Alex Kleon (Sun Jul 13, 2014 7:07 pm)
PostPosted: Mon Jul 14, 2014 8:26 am
I just pencil mark the two outer strings and eyeball the rest. Sometimes they come out like eek , sometimes like :? and occasionally like [:Y:] . Mostly they are :|
PostPosted: Mon Jul 14, 2014 8:51 am
Hi Frank,
Thank you for sharing that method for making a string spacing rule. I will have to try my hand at making one. I usually determine the outside string locations and then do a calculation in millimeters of the spaces in between, adding or subtracting 1/2mms to come up with the spacing. My natural parsimonious-ness keeps me from buying the Stew mac rule, and your method looks like it will work fine.
Thanks again!
PostPosted: Mon Jul 14, 2014 9:16 am
First name: Edzard
Last Name: Kolks
City: Eindhoven
Country: The Netherlands
I use these.
Regards,
Edzard
PostPosted: Mon Jul 14, 2014 11:14 am
First name: Wendy
Last Name: W
State: Arizona
Thanks for that Frank.
PostPosted: Mon Jul 14, 2014 9:45 pm
Frank, Cool! Edz, where did you get that?
cron
