It is currently Sun Jul 27, 2025 11:06 pm
PostPosted: Thu Jul 31, 2014 2:38 pm
Last Name: Sollod
How do you finish the inside area of a slot head? It seems that it would be tough to level sand and wet sand that surface and impossible to buff. Maybe buffing isn't necessary in this area, but what about level sanding? ...especially without sanding through at the tuner holes.
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: jshelton (Thu Jul 31, 2014 4:50 pm)
PostPosted: Thu Jul 31, 2014 3:57 pm
It's like buffing the inside of the scroll on an F5 mandolin.
I sand with 120 before finish and 220 and 400 before the final coats and call that good enough. Anyone that wants it spotless in there doesn't want one of my guitars...or mandolins for that matter.
PostPosted: Thu Jul 31, 2014 4:08 pm
Last one I did I level sanded to 2000 and hand buffed. I used drafting erasers cut into convenient shapes. It was a PITA. I like Haans' method better.
PostPosted: Thu Jul 31, 2014 4:36 pm
You can glue sandpaper to HPL and make some home made emery boards. That helps smooth things up. I brush on lacquer in that area before spraying the neck, level it as best I can , and not worry too much about it.
PostPosted: Fri Aug 01, 2014 5:24 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
My big buffer gets the ramps no problem and my finish off the gun is usually good enough that I don't need to worry about the sides of the slot.
Brian
PostPosted: Fri Aug 01, 2014 8:37 am
I have told prospective clients that if they want the inside of the scroll polished or slots polished, the added price is $1K. Have never felt that those were important. It's another case of where manufacturers are catering to those that are more interested in the absolute perfection of the fit and finish than anything else, like tone.
Handmade instruments have maker's marks.
PostPosted: Fri Aug 01, 2014 9:42 am
I get it up to 320 then use a rag with polish and proceed like I am shining shoes.
These users thanked the author jfmckenna for the post: mqbernardo (Fri Aug 01, 2014 12:03 pm)
PostPosted: Fri Aug 01, 2014 10:28 am
I am going to Tru-oil on the string slots.
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Aug 07, 2014 7:39 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I use Waterlox on my necks (high solids modified tung oil), and finish like jfmckenna does. I like a satin finish
neck. Haven't had anyone complain about them yet.
Gene
PostPosted: Fri Aug 08, 2014 12:42 pm
Last Name: Vallandigham
City: Martinez
I sand the area (including the ramp) as I'm applying varnish (between coats) but the final coat, I just leave it gloss varnish. I do not wet sand and buff the inside of the slots or the ramp. Once you buff the front and back of the headstock, it all blends right together.
PostPosted: Fri Aug 08, 2014 6:35 pm
First name: Ringo
I don't sand or buff the inside of the slots' finish, but if it's light colored wood I stain it pretty dark before finishing to keep the area as shadowy and inconspicuous as is practical.
Users browsing this forum: doncaparker, J De Rocher, meddlingfool and 9 guests
