It is currently Fri Aug 01, 2025 7:54 am
PostPosted: Mon Dec 01, 2014 12:03 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
We have a very nice fingerboard from Craig Lavin for a build we are doing.
Now we need to glue in the frets to keep from chipping the inlay - and I have NO idea how to proceed.
My concerns/questions are:
1) I've been told to flatten down the tangs to keep from chipping the inlay - so how exactly do I glue these in after flattening so they won't come out easily?
2) What type of glue? CA?
3) I need to avoid squeeze-out as I can't sand the fingerboard - or I will possibly ruin the inlay. This is probably my biggest worry right now. [uncle] [uncle] [uncle]
ANY and ALL help and advice GREATLY appreciated!
Thanks!
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Dec 01, 2014 12:24 pm
City: Tyler
Paul, you can remove the barbs from the tang and glue in with a drop of CA on each side. This tool removes the barb, or you can make your own with 2 pieces of a file in a vise.
http://www.stewmac.com/How-To/Online_Resources/Fretting/Fret_Barber_Instructions.html
PostPosted: Mon Dec 01, 2014 12:49 pm
Clean up the squeeze out with a rag dampened with acetone.
PostPosted: Mon Dec 01, 2014 12:55 pm
Last Name: Burner
City: Lincoln
State: Nebraska
When It is dry?
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Dec 01, 2014 1:31 pm
No, when it is wet. Or as quickly as possible. The sooner you clean it up, the easier it is to remove all traces of squeeze out.
PostPosted: Mon Dec 01, 2014 2:39 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
Make sure you file the inlay. I use a triangle file run down the fret slot. A square file would probably work as well.
Michael F Smith
Goat Rock Ukulele
http://goatrockukulele.com
PostPosted: Mon Dec 01, 2014 2:43 pm
Paul, I rout the areas where the inlay crosses a fret slot with a tapered bit set to rout a bit wider than the tangs. That way you can still use the fret as is and I use a white or yellow glue to set the frets instead of cyano. It;s less messy...
