It is currently Fri Aug 08, 2025 1:08 pm
PostPosted: Sat May 16, 2015 4:25 pm
First name: Ringo
I'm doing a bunch of pattern routing in the next couple of weeks and figure putting foam/rubber tape on both sides of my templates and using them as both vacuum clamp and pattern will work best. There seems to be a dizzying array of foam/rubber tapes on the market advertised as various weatherstripping and gasket tapes... what's the best to use for this application?
PostPosted: Sat May 16, 2015 6:17 pm
Look for something that is closed cell. I got what I use from Joe Woodworker.
These users thanked the author SteveSmith for the post: James Ringelspaugh (Sun May 17, 2015 8:11 pm)
PostPosted: Sun May 17, 2015 9:44 am
First name: Fred
City: Winnipeg
Maybe not the best but it was cheap and within reach.
These users thanked the author printer2 for the post (total 2): Pmaj7 (Mon May 18, 2015 9:48 am) • pdolan (Sun May 17, 2015 7:17 pm)
PostPosted: Sun May 17, 2015 11:29 am
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I love it! Very creative Printer2! Is that just saran wrap?
PostPosted: Sun May 17, 2015 11:54 am
First name: Fred
City: Winnipeg
The one and only. Well maybe not only.
These users thanked the author printer2 for the post (total 2): Pmaj7 (Mon May 18, 2015 9:49 am) • Imbler (Sun May 17, 2015 2:01 pm)
PostPosted: Sun May 17, 2015 2:12 pm
Check into Allstar Adhesives... They have all kinds of stuff.
http://www.allstaradhesives.com/
These users thanked the author Don Williams for the post: James Ringelspaugh (Sun May 17, 2015 8:12 pm)
PostPosted: Sun May 17, 2015 2:20 pm
I've purchased the stuff Joe WW sells and also used the water seal adhesive back rubber found in the RV and boat maintenance supply stores.
Ken Cierp
These users thanked the author kencierp for the post: James Ringelspaugh (Sun May 17, 2015 8:12 pm)
PostPosted: Sun May 17, 2015 6:55 pm
+1 on Allstar Adhesives.
o-ring cord stock also works.
Here another low tech clamping bag, which works pretty well actually.
These users thanked the author Jim Watts for the post: James Ringelspaugh (Sun May 17, 2015 8:17 pm)
PostPosted: Sun May 17, 2015 11:08 pm
Last Name: Garrish
Neoprene round cord is where it's at.
As others said: if you can't get it locally, Allstar Adhesives has what you need. The round cord works best, and I use it with a square bottom groove cut just a bit over half its diameter. I use the 3/16" stuff just because.
Pretty much anything works well as a vacuum bag- we often use clear garbage bags at work. You can seal the bag to the hose with electrical tape, or even a few zip ties.
Bob Garrish
These users thanked the author Bob Garrish for the post (total 2): James Ringelspaugh (Mon May 18, 2015 11:59 am) • Pmaj7 (Mon May 18, 2015 9:50 am)
PostPosted: Mon May 18, 2015 11:59 am
First name: Ringo
Thanks all... turns out I can use some new veneering supplies too so I went with this Joe Woodworker tape: http://www.veneersupplies.com/products/ ... x-100.html
PostPosted: Mon May 18, 2015 12:36 pm
That's what I was referring to.
PostPosted: Mon May 18, 2015 12:44 pm
Yep -- that's the stuff -- sticks good, functions perfectly.
Ken Cierp
Users browsing this forum: No registered users and 40 guests
