It is currently Sun Aug 17, 2025 12:46 pm
PostPosted: Wed May 27, 2015 3:47 am
I'm going to be using a tower type binding jig.
How to prevent cutting into the neck with the bit?
I'm not so confident to "just stop short" of the neck wood, and the heel area is mostly pre-shaped.
I was thinking to HHG small blocks at the heel area as stops for the bit bearing.
Any better suggestions??
PostPosted: Wed May 27, 2015 8:40 am
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
That's what I do. I make sure to leave at least .125 (I use a .120 wide ledge) in the heel area, or put sacrificial blocks in the heel area. Otherwise, I wind up stopping too far from the neck, and generally not doing a smooth job in that area. You can use spruce so it is very easy to carve away after you are done,
PostPosted: Wed May 27, 2015 8:48 am
Last Name: Lazar
City: St. Albert
State: Alberta
Zip/Postal Code: T8N 5Y6
Another way might be to clamp something to the top of the neck which would act as a stop for the edge of your router base. The size of the base may or may not work for this.
These users thanked the author mflazar for the post: Imbler (Fri Jun 19, 2015 8:19 am)
PostPosted: Wed May 27, 2015 10:29 am
First name: Martin
Last Name: Kelly
City: Tampa
State: FL
Zip/Postal Code: 33634
Although I'm always a bit nervous when cutting binding ledges, I've not yet (on my 11th classical) had a problem with this part of the process. I just move real slow when I get close to the neck and make sure I have plenty of light on the situation (do my routing on a table in the out of doors).
Users browsing this forum: DennisK and 26 guests
