It is currently Tue Aug 12, 2025 12:33 am
 Post subject: Source for Ebony veneer?
PostPosted: Wed Jul 08, 2015 7:36 pm
First name: Tom
Last Name: Neal
City: Hudson
State: Illinois
Looking for ebony veneer for armrests and the like.
Thanks!
T
PostPosted: Wed Jul 08, 2015 7:44 pm
First name: D
Last Name: S
http://www.veneersupplies.com
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Jul 09, 2015 7:36 pm
First name: Danny
Last Name: Vincent
Black dyed veneer works well. It, like Ebony, looks just like black plastic under finish. I think I'm going to give black veneer a try for bound head plates. I can't see any reason not to. I would laminate it to a backer to make up 1/8" plate to support the nut. You would see the line with the nut out however.
PostPosted: Fri Jul 10, 2015 7:24 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
certainlywood.com has some quartered macassar that is pretty dark but not 100% black + dyed black stuff
Mike McNerney
PostPosted: Mon Jul 13, 2015 7:02 am
Last Name: O'Melia
City: Huntsville
State: Alabama
If you have a thickness sander, call Hibdon for some scraps of African Blackwood. I was able to sand to .6 mm on a raised bed. They have cutoff and odds and ends they will sell.
PostPosted: Mon Jul 13, 2015 5:38 pm
First name: Fred
City: Winnipeg
I just tried Ebonizing a piece of Jatoba. Sanded the bottom half with 400 grit, should have wiped it with something befor taking the picture. Might be an option using woods that blacken using steel wool dissolved in vinegar. Heard Walnut darkens up also. I got a few lengths of Jatoba that were cut for flooring and have been using it for fretboards. Going to have to see how the black holds up under strings.
PostPosted: Mon Jul 13, 2015 9:39 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Nice stuff that African Blackwood. Really bends nicely. Great veneer.
PostPosted: Tue Jul 14, 2015 8:29 am
First name: Tom
Last Name: Neal
City: Hudson
State: Illinois
I ordered some Gaboon and Macassar from Veneer Supplies. Should have it today. Thanks for the suggestion!
I hope to match some bindings I have from Allied. We will see...
I have used black fiber in the past but was never happy with the results. I don't care for the color variance in the layers after sanding.
I will check with Hibbdon for future needs. Thanks Mike!
T
PostPosted: Tue Jul 14, 2015 11:18 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm sure what ur doing will work fine. Heck, had I known about these veneers, I might have tried them. Part of me just wants to use the same material all the way around. When I found out I could buy "scraps" from Hibdon, it was then just a matter of challenge to get it thin enough. Which I enjoyed doing. :)
PostPosted: Mon Jul 27, 2015 9:11 am
First name: Rahoul
Last Name: waghmare
City: pune
State: maharashtra
Zip/Postal Code: 411044
Country: india
sir what size u want?
i can supply if u want
Users browsing this forum: No registered users and 59 guests
