It is currently Fri Aug 01, 2025 7:06 am
 Post subject: Safe Temporary Adhesive
PostPosted: Mon Sep 07, 2015 9:26 pm
Does anyone know of a safe temporary adhesive that I can use on the back of thin sandpaper? I need it to be ok to use on a finished guitar body (ie. - the body has been sprayed and buffed out) when doing the final adjustment of the neck fit.
I will be adhering the sandpaper on the body around the dovetail area and moving the neck back and forth over the paper for the final fit.
( The 3m Stikit paper is just too thick for what I want to do.)
Bill
Formerly know as Mandodiddle.
PostPosted: Mon Sep 07, 2015 11:42 pm
Is that from the Mayes video?
At Larrivee, we used to lay down a strip of painters tape (not as thick height wise as regular masking tape) under the cheeks of the heel to protect the finish, then flossed with a hard back 180 grit paper.
These days what I, and many others do, is to use packing tape on the back of the sandpaper. It is easier to hold the neck and pull the sandpaper out in a stripping motion. Always make sure you bend the sandpaper down towards the butt and not up towards the headstock. It's a lot easier then tacking down the paper and moving the neck.
PostPosted: Tue Sep 08, 2015 8:40 am
First name: Tom
Last Name: West
State: Nova Scotia
I think it is also more accurate with a better result when done as Ed suggests. At least for me it is.
Tom
PostPosted: Tue Sep 08, 2015 8:55 am
I also use clear packing tape on the back of the sandpaper strips. Has not damaged the finish.
You can get some small chip out on the edges of the cheeks and the heel cap on a finished guitar with heavier grits. I try not to go above 220 and usually start with 320 to kind of smooth the edge of the finish before going to a higher grit.
If they are small repair has not been difficult.
PostPosted: Tue Sep 08, 2015 10:01 am
So you are wanting a double sided tape? One option would be to just use glue and then soak if off when you are done. Elmer's White Glue can easily dissolve when you apply some warm water to it.
PostPosted: Tue Sep 08, 2015 11:10 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I have a spiral bound pack of plastic shim stock with 15 different sheets that are 5"x20" and range from .0005-.030. Using the 3M Stikit on top I can cut any size of sanding strip in any thickness I need.
PostPosted: Wed Sep 09, 2015 6:12 am
+1 on Ed's suggestion about using packing tape on the back of the sandpaper.
Max
Max Bishop
Brighton, Michigan
PostPosted: Wed Sep 09, 2015 12:29 pm
Yes --- plastic packing tape applied to the abrasive --- move the paper not the neck.
Ken Cierp
PostPosted: Fri Sep 11, 2015 5:05 pm
I've been using powdercoating tape.
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Sat Sep 12, 2015 10:15 am
One of the features of powder coating tape is silicone adhesive.
Ken Cierp
Ken Cierp
PostPosted: Tue Sep 15, 2015 10:37 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Glue stick has worked for me. It is best if you can clean up with a little water (no bare wood).
